Engine Oil Leak and Overheat
08.05.2020 17:36 # 1
kasirga16
Friends 307 sw automatic car temperature does not go below 100, the fan is running, but it is the lowest 100 in the course of the traffic. Is it normal for the temperature to be this way or should a reason be sought?
There's also oil leaks around the engine bay, some masters are talking about sweating, how exactly is this happening?
respects.
08.05.2020 17:36 # 2
elsoberano
It is necessary to find 90 normal ones in 100 traffic jams and decrease when the fan turns on the 2nd stage (up to 90`s).
08.05.2020 17:36 # 3
SDYMZ
It is definitely not normal for the 120 to come out after you have finished the water. If you have checked the temperature, take it to the master or you will burn a gasket or something.
08.05.2020 17:36 # 4
cocomo
bro the car boils the water you know.
and maybe the lid seal may be leaking oil. I think you should put the car in heavy maintenance in the most urgent way.
08.05.2020 17:36 # 5
samet206
120 It is not normal, not strictly. If the water is decreasing, it is necessary to investigate the reason, water is boiling, there may be a leak.
08.05.2020 17:36 # 6
Rebel35
I have the same vehicle in me, the temperature does not reach 90 while cruising, the fan runs on the line after 90 at the most in heavy traffic and it drops to 90a again.
08.05.2020 17:36 # 7
kasirga16
Hodja, I was thoroughly afraid, after the comments, the detour appeared to me as soon as possible :(
08.05.2020 17:36 # 8
allppeerr
it can be very simple, something that can be challenging. just show it as someone who has renewed the motor on brodway just because of the fan sender
08.05.2020 17:36 # 9
EErgul
Doesn't the stop light come on? I had a friend of mine, this malfunction again, he changed the oil, changed the water, cleaned it now. Let the heat come well.
but 3-5 months ago, a female friend had a subject here related to the same problem. He had changed a lot of pieces, he could not solve it, he had solved it with one last piece. I guess it changed the brain, but I can't remember exactly.
08.05.2020 17:36 # 10
allppeerr
It doesn't necessarily mean that when there is a problem, the stop light will not be lit.
08.05.2020 17:36 # 11
kasirga16
The car does not give any warning, but last year the long-term air conditioner was turned on and in the summer, the car had turned itself off in heat and my smart driver friend opened the hood and poured water with the engine next to him, I was in another car, the car did not start when I came near the car, we later looked at the battery finished, engine blocks from Allah were not damaged,
That day, a heat problem that I was disturbed in the vehicle started.
