Engine oil finished ..
08.05.2020 15:00 # 1
tigerland
I noticed that the engine oil was running out in my friends. There was no problem when I left work. I realized the sound coming from approaching the house, the sound was coming from the engine. I parked in front of the house and searched for the oil, told me to check the oil, the oil was below the finished minimum and I stopped and the master will come on Monday and add oil to the car.
& nbsp;
What do you think is likely to have damaged the engine?
08.05.2020 15:00 # 2
C!N
Doesn't the text `` STOP '' write when the oil runs out, does the car not give any warning?
08.05.2020 15:00 # 3
tigerland
No, I stopped the car without warning, I immediately listened to the master, said "Stop" and I stopped the car immediately.
08.05.2020 15:00 # 4
Onur
I hope it hasn't hurt my lubrication lamp never burned
08.05.2020 15:00 # 5
tigerland
I checked the oil cubes immediately and found that it was under the bottom line. Before stopping from the engine, there was a steady sound coming out of it. It sounded like a diesel.
08.05.2020 15:00 # 6
tigerland
[QUOTE = Honor] I hope it did not hurt I did not light up the lubrication lamp [/ QUOTE]
no lamp did not alert, I opened the window, I noticed a sound, the lamp did not burn. I stopped the car now master gelck p.tesi will look. I noticed my friends on time.
& nbsp;
did it damage the valves? There was a little tipping sound
08.05.2020 15:00 # 7
Onur
If it did not give a warning that you stopped immediately, there is some oil in the engine. I hope there is no problem in the engine. Why did the engine drop so much oil?
08.05.2020 15:00 # 8
tigerland
crankcase crack small & nbsp; but it was last week oil max. When I was under 2 mm, I couldn't make sense of how bugn has been reduced.
& nbsp;
this evening I looked under the oil under the min .. 3 mm sticks to the dipstick, little oil remained
& nbsp;
valves are intact. I am facing a problem with the first time division
08.05.2020 15:00 # 9
Onur
I hope there is no problem.
08.05.2020 15:00 # 10
Get well, don't worry, don't worry, nothing has happened.
08.05.2020 15:00 # 11
tigerland
"Laugh" build. sat inside of me, sleep night and night :)
08.05.2020 15:00 # 12
tigerland
[QUOTE = Honor] I hope there is no problem, get over the valves, never forget the valves in the engine. He said he should be prepared ... he should quit smoking on the 4th day :) a good reason to keep the man smoking :)
08.05.2020 15:00 # 13
do not start, here is the cost of the car with the money you will give to the cigarette, man, do not start. you have it and until you stop but it is not a problem to run again. Also, you changed the oil for the last time. It is neglected.
08.05.2020 15:00 # 14
C!N
Wasn't the oil level on the screen low when it turned on the ignition, wasn't it?
08.05.2020 15:00 # 15
dbmaster
Interestingly, when the oil decreases, stop warning. The car stops.
08.05.2020 15:00 # 16
tigerland
I think the warning lamp did not light up on the indicator because the oil was not completely finished, but when I lowered the window, I noticed that there was a small noise coming from the engine and then I parked the car and stapled it.
08.05.2020 15:00 # 17
What do you have to do? Have to check the oil from day to day without trusting the oil lamp ... by the way, bro. If you know that the car is low in fat, you don't add it, my beautiful brother. Do not get in touch with the missing oil. Then a lot of expenses will open up.
08.05.2020 15:00 # 18
tigerland
I did not add
because I was going to leave it on Tuesday already & nbsp; I made an appointment from the master. If there is any problem in the valve or engine that is on my mind from the short distance god, the simple master will add the future oil, if the engine continues to work normally, the engine is OK but if the sound continues, the valves are different I guess I would create such a problem. it's just
08.05.2020 15:00 # 19
There is a possibility to create, but I hope it won't be a problem ...
08.05.2020 15:00 # 20
Haksen016
Hopefully,
Page : / 3
