Engine oil and noise
08.05.2020 18:44 # 1
tegote
I walked a bit in the forum but I wanted to ask because I couldn't find the answer I was looking for. My vehicle is 307 1.4 xr gasoline lpg li 2005, over Km 150 thousand.
I'm in trouble engine noise. I had a new maintenance on my vehicle, I think the problem is in the oil, but I wanted to refer to your experience. The engine started to work more loudly, the engine running between 90-95 fever often goes up to 97s and turns on the fan. Even if it does not pose a big problem, the person is disturbed.1-2 I showed it to the answer. The pejo works hot :) I know this already. I do not know how to get on the pejo. I did not change the case, now I connect the motor oil to the engine oil when I start it 2 times when it is cold and when the temperature exceeds 90, the disturbing engine noise starts in the car. While getting up comfortably on a solid slope at 2, now it shakes a lot when the engine is hot. (I just replaced the spark plugs coil or something, new filters including batteries)
I have a friend who will suggest an oil that will reduce the sound and affect the high temperature.
Or could there be a different reason for this problem?
Can castrol 5w40 fully meet my synthetic expectations? Is there any obvious difference using additive boron ws? Pejo recommends 5w 40. I say let's get a full synthetic oil for 3 cents more. There are a lot of suggestions for mobile 0-40 full synthetics, but I do not think much of oil reduction in the lpg vehicle.
Note: I checked the service says that there is no problem with sound, everything is normal, but the user knows it is different from the previous version.
08.05.2020 18:44 # 2
BurakCnR
I had the same trouble, I had the maintenance last year, Castrol put 10/40, the sound of the engine got louder and even I wrote here in the forum, thanks guys. I went to the service 2 weeks ago, they told me to add Total 5/30 oil. I bought Total 5/30 too, I don't hear the engine sound right now :)
08.05.2020 18:44 # 3
emrepunar
slm I have been using the 307 sw 2006 model for 7 months and I have never seen that my fever has been over 90. When it comes to the motor oil issue, I put castrol 5/10 a month ago, and the noise in my mind started to increase, it will be okay when I will go and show it to me.
08.05.2020 18:44 # 4
tegote
If it was neo, it was in the last maintenance. I changed it to something like that. the engine may be cracking when replacing the trunk, one of the bearings was making a sound I changed it, there was no sound for 1-2 days, then I made a long road about 300km, which was after that, the car started to heat up very clearly. I showed it to 3 places in 3 says everything is normal. The sound coming from the bearing was evident, this obvious engine sound was like a 3-hour hill climb. The city often goes up to the 97's, it opens the fan, especially if I ran the bidet air conditioner, the fan sound like the old electric brooms. I'm going to make a change of oil this week, let me try castrol edge 5w40 fully synthetic.
08.05.2020 18:44 # 5
tegote
If friends are not an important issue, let me write that it will be useful for me. Today, I bought oil castrol edge 5w40 full synthetic and replaced it with all filters. I used it for about 2-3 hours, now the engine sound became number 10, traction increased. As for the temperature, I changed the oil in the pejo service, I examined it, the guys say it is very normal and it says nothing else between 95-104, they say the temperature that your car is working most efficiently. As a result, it should not be said to pass the oil, the sound went away and the heat was seen at most. Of course, when the oil is a little old in the future, I don't know the neolur. When I was looking for the problem elsewhere, I spent up to 500 liras on timing bearings and radiator system pipes etc. they became bracelets. oil is 85 lira with original filters and 90 lira with hand labor. I gave a total of 175 lira. When it comes to cheaper, there is nothing in hand. 10 oil of total oil put by old oil sdantard pejo services.
08.05.2020 18:44 # 6
Ali1905
The water boils at 100, but we do not only use water in our vehicle, we use a mixture of water and antifreeze. Boiling point rises quite a bit, do not worry.
08.05.2020 18:44 # 7
mustafa_nalcacioglu
If you ask for the uneven start in the engine, you said that I changed the back when you have the maintenance done.
08.05.2020 18:44 # 8
Ali1905
briefly look at the sentence setting
