engine oil
08.05.2020 15:33 # 1
It's time to replace the 1.6 8v 206 xs gasoline engine oil. which oil would be number 10 :)))
08.05.2020 15:33 # 2
werty
I recommend you to put mobil 1 new life 0 - 40 and I use the same oil. In the forum, this issue had been painful before. In line with the proposed mobile 1.
08.05.2020 15:33 # 3
Let's say mobile 1 was accepted 0-40 or 10-40 ???
08.05.2020 15:33 # 4
fTh206
I changed it a month ago, I had put a helix brand in the shell, I don't know if it is good but I do not know :)
08.05.2020 15:33 # 5
voodoo
mobil 1 is the best for me .. i recommend you to put new formula in new life.0 - 40
08.05.2020 15:33 # 6
Use your preference for fully synthetic oils. I think you will be satisfied if you use an oil of 0W-40 or 5W-40 without changing the end number 40.
08.05.2020 15:33 # 7
okan77
What is the difference of being 0 - 5 - 10/40 briefly? Which 4 seasons are ideal?
08.05.2020 15:33 # 8
[QUOTE = okan77] What is the difference of being 0 - 5 - 10/40 briefly? Which 4 Seasons is ideal? [/ QUOTE]
If you want the same performance in 4 seasons, you can use mobile 2000 10/40.
08.05.2020 15:33 # 9
Every oil in our day is already 4 seasons. In the past, there was only one oil number, for example, they put 40 number oil. This oil would be replaced with different numbers of oils in winter care and summer care. Nowadays technology can produce oils with different viscosity in cold and different viscosity in hot. For example, the oil you call 10W-40 has a viscosity of 10 when it is cold, that is, when the engine is cold, and 40 of it when it is hot. The recommended value is to have 40 viscosity when the engine is hot. However, when the engine is cold, it can be played according to the situation and demand. As you said, someone between 0-5-10 values can be preferred. Number 0 can lubricate better than number 10 because it is more fluid. I also use 0W-40 in my own vehicle.
08.05.2020 15:33 # 10
[QUOTE = ose307] [QUOTE = okan77] What is the difference of being 0 - 5 - 10/40 briefly? Which 4 Seasons is ideal? [/ QUOTE]
Your synergistic oil is semi-synthetic ... It is more useful to use full synthetic. But more expensive of course :))
It is possible to use Moble Super 3000 X1 5-40 or Moble 1 New Lifetime 0-40, as it is shown in my signature and above. There is nothing wrong with using these oils in summer.
Summer oil was old. Because oil technologies are very advanced ... You can also use full synthetic oils with longer km period.
I work on the basis of myself making an idea about the oil life. Every 2500 km, I take a picture about oil color and creature by applying it with oil and handkerchief. I took a picture in 2500, and I am going to shoot it when I go to 3200 km with oil, like new :)) 5000 7500, etc. I will use it :)) and 15.000 km. When the km is completed, the subject will hurt and share the pictures ...
Let me show you the color of my 2700km of oil. Meanwhile, my oil level is in the middle. Do not say why it is less or less. Because 4.75 lt of oil is like this when you put 4 lt of oil into the engine :))
The first oil remains in the same place since I changed it.
the cecol 2011-06-07 12:19:21
08.05.2020 15:33 # 11
trtolgi
My friend enter the web address of mobile or another oil company. After entering the properties of the vehicle there, it gives the vehicle what the best oil is. They usually give you 0-40 or 5-40. As the friends say, you should consider the synthetic and semi-synthetic properties.
