Engine oil
08.05.2020 16:25 # 1
xpyhre
If we buy engine oil, can we do the filling process ourselves ..?
08.05.2020 16:25 # 2
If you can empty it, it is simple to fill.
08.05.2020 16:25 # 3
xpyhre
[QUOTE = laedri] Simple to fill if you can empty it. [/ QUOTE]
How can I drain it, teacher .. Do you have any fat suggestions for 206 gti?
xpyhre 2011-12-02 19:06:18
08.05.2020 16:25 # 4
You should lift the vehicle on the fiber and drain the old oil from the crankcase. After the oil draining process, you should change the oil filter. Then you should add 5-40 or 10-40 oil to your vehicle and let it run at idling. If you don't know much about it, you should have this process done by any engine master for about 20 TL. Because it is a serious job that looks simple, oil change.
08.05.2020 16:25 # 5
If your hand is lying, why not. I am changing everything myself & nbsp; "Approve"
08.05.2020 16:25 # 6
xpyhre
Thank you for the information.
08.05.2020 16:25 # 7
If I had a walla lift, I have the courage to everything but :)
08.05.2020 16:25 # 8
xpyhre
& Nbsp; Walla teacher, I will raise it with two jacks right and left, and I will make a wisdom. This wonder will leave me under the car someday but when .. :) & nbsp; xpyhre 2011-12-02 20:03:28
08.05.2020 16:25 # 9
Fasten the vehicle with the wedge. Safety is important. When you lift it with a jack, the front of the vehicle stays in the air more than the rear of the vehicle.
08.05.2020 16:25 # 10
Ucyuzalti
Warranty & nbsp; Whether I had it for free & nbsp;
08.05.2020 16:25 # 11
In the meantime, let me say the presentation, if you do not lower your vehicle, there is no need to jack up the vehicle for oil change. You can reach the stopper with your arm & nbsp; "Wink"
Of course, the oil filter is reached from the top for the 307 I have mentioned. In the 206s, you have to insert the filter from below. The picture below shows the oil filter and crankcase plug of the 206 gti.
koliva 2011-12-02 21:11:56
08.05.2020 16:25 # 12
voodoo
dude your car 4.2 liter oil alior according to it ... now i want to put it in mobile 1 new life series in oil ....
voodoo 2011-12-02 21: 48:00
08.05.2020 16:25 # 13
djchaos
I think take it to the people of your work, see it well, if you get used to it, if there is a master you know, please ask me to take the car, do not forget about the car yourself.
08.05.2020 16:25 # 14
xpyhre
& nbsp; [QUOTE = voodoo] dude your car is 4.2 liters of oil according to him ... let's come easy from now i put it in mobile 1 new life series .... [/ QUOTE]
dude. p>
08.05.2020 16:25 # 15
06OzGuR06
It is better if you drain the oil while the engine is hot because it becomes more fluid and drains quickly.
08.05.2020 16:25 # 16
voodoo
This is the amount of oil your vehicle's engine takes in your booklet .... 206 gti takes 4.2 liters of oil .... you will put it with a biscuit like a milligram-sized container ... but make sure the oil is poured beautifully ... refresh every time the oil changes ... When it comes to oil, it is the most important oil for me .... http://www.mobil1.com.tr/otomobil-motor-yaglari/new-life-0w-40.aspx
08.05.2020 16:25 # 17
xpyhre
Thank you guys. It was very acceptable.
