Engine noise increased after maintenance
08.05.2020 21:08 # 1
aSeydioglu
After disrupting the maintenance of my car for a long time, I left it to a familiar master for oil care. Everything changed 5-40 oil, hydraulic transmission oil checked card I suspended back.
Question 1-) What happened to the car, including myself, was said why it makes so much noise to this car. (5 people said until tonight)
Question 2-) The middle bottom of the windscreen, the back of the road computer, is presumably a peculiar sound as if the air filter runs down the gas at the bottom of the hood, and the leaves are filled, as if the air is trying to pass through it. (It is not a turbo sound, I am familiar with the turbo, I had difficulties, it was revised, it did not improve, etc.)
I showed it to a different master.
I am confused by someone who wore the confused air filter crookedly, what might have done to increase the sound of the engine? Thank you already.
the aseydiogl 2019-01-29 02:05:13
08.05.2020 21:08 # 2
samet2461
The place of the air hose connected to the first air filter box was removed from the suction place, and it happened to me.
It stays behind the air filter box
samet2461 2019-01-29 07:06:13
08.05.2020 21:08 # 3
which oil has been put into the car before and thicker oil has been reduced. When you put thin oil, the volume is normal. Check the air filter hoses as our friend said, they may not have tightened.
08.05.2020 21:08 # 4
aSeydioglu
[QUOTE = samet2461] The location of the air hose connected to the first air filter box from the suction point has come out, it has happened to me.
Is it something I can do? According to him, let's go to the car and tamper
08.05.2020 21:08 # 5
aSeydioglu
[QUOTE = sonerkyl] Reduces the sound slightly, whichever oil was put into the car before and thicker oil was put in. When you put thin oil, the volume is normal. Check the air filter hoses as our friend says they may not have been tightened. [/ QUOTE]
I swear what I would lie before, I never looked at which oil subject Cry
08.05.2020 21:08 # 6
[QUOTE = aSeydioglu] [QUOTE = sonerkyl] reduces the sound a bit, whichever oil was put in the car before and thicker oil was put in. When you put thin oil, the volume is normal. Check the air filter hoses as our friend says they may not have been tightened. [/ QUOTE]
My teacher, who is important in following him, is not always good for oil engine with different brands and features. some of us put 10w / 40 oil, engine noise is reduced. some puts 5w / 30, the sound is cut but the engine runs smoothly. 5w / 30 and 5w / 40 are ideal for your vehicle. But they usually put 10w / 40 oil in many services.
08.05.2020 21:08 # 7
aSeydioglu
How many w 40 were there before that sounds silent, or let me say, is there a chance of oil shortage. Poor quality etc. Do you have a big harm?
08.05.2020 21:08 # 8
Frt-Aydin
soner brother 206 which oil do you recommend 5 30 let's put 10 40 mi which brand
Bid somewhere, you have written an engine internal cleaner, will it be a problem for my car, will I encounter oil reduction in the future, I wonder if it has blocked a thin hole, let's not open them.
08.05.2020 21:08 # 9
[QUOTE = Frt-Aydin] [QUOTE = sonerkyl] reduces the sound a bit, whichever oil was put in the car before, and thicker oil was added. When you put thin oil, the volume is normal. Check the air filter hoses as our friend says they may not have been tightened. [/ QUOTE]
it is not clear there may be a problem in old vehicles. If it is too dirty, it can cause clogging. 10w / 40 is ideal in 206s.
08.05.2020 21:08 # 10
Frt-Aydin
thanks brother
08.05.2020 21:08 # 11
aSeydioglu
Thanks for your help. The air filter boiler cracked, said the master, said that he could make a sound from there. 150 tl + gasket changed and engine washed. When I bought the car, I thought it was gasoline, I thought it was so noticeable
08.05.2020 21:08 # 12
We are welcome, teacher, thanks for the feedback and information.
08.05.2020 21:08 # 13
recepagdas
is this the big black plastic box where we put the air filter in the place you call this air filter boiler?
02.03.2021 23:35 # 14
hakbulut61
I have the same problem, they checked the hoses. Nothing. When the vehicle is forced or even two, it sounds like a diesel engine. Let me look at the box &# 128077;
03.03.2021 09:45 # 15
hakbulut61
Sir, are you in Istanbul? Where did you get it done?
