Engine Mount 1.4HDi
08.05.2020 18:08 # 1
Alicilik
Hello friends,
Today we were talking about problems and problems while chatting with a friend who has 206+.
He told me about the problem in the motor ear.
He said that his vehicle deforms every 20 thousand km of engine ears and this situation may damage the chassis in the long term.
1.4 HDi users know that the engine will go officially at the first start and you can see clearly. While working, he works very shakyly in the same way. I didn't care about it because it was diesel, but after what was told, my mind got stuck.
My car was last serviced for 45 thousand and now 48 thousand servsi or the place where we had the last maintenance did not mention such thing.
How can we perceive this situation really be like this?
08.05.2020 18:08 # 2
Serkan
You know, if you shake the engine with your hand, Ali plays as if there is a gap, the engine, and when he goes on normal gas, he pulls his foot out of the gas and shakes the car forward, maybe it was the head of my friend but I did not hear a chronic problem, I bought 206 in 72 thousand km, I changed the engine wedge in 119 thousand. What damage can the chassis do unless the engine falls on the chassis? Serkan 2013-12-16 01:11:09
08.05.2020 18:08 # 3
Alicilik
[QUOTE = Serkan] You know if you shake the engine with your hand, Ali plays as if there is a gap, the engine will shake the car forward when you go in normal gas, maybe it came to your friend, but I did not hear a chronic problem, I got 206 in 72 thousand km. I changed the engine mount to 119 thousand, what damage can the chassis do if the engine does not fall into the chassis? [/ QUOTE]
I couldn't get up and look at the car, but when I went to an industry, I would lift the fiber and look. When I told my friend, he caught my attention.
I do not know the Zaar situation, but the engine could not play that much, and the damage to the supports will not produce a pleasant result. Reviews
08.05.2020 18:08 # 4
halilefe
My vehicle is 110 thousand, I have Hdi maintenance in the service, they did not tell me, I did not change it any more, but it is as if it is not a part that often fails. the tool is 160 thousand.
08.05.2020 18:08 # 5
kuscu38
the engine's ear is a piece of iron, a bit like a thick plastic, like rubber, the engine shakes, so it makes you feel the vibration to a minimum and if serkan is on the chassis as you say, you are right if you and I may have refuted the chassis over time but I have never seen it! ! !
08.05.2020 18:08 # 6
Alicilik
I do not know that there is no foundation for the subject. I'll make you look at it soon
08.05.2020 18:08 # 7
Sertan
In my vehicle & nbsp; especially when idling, there was an excessive shaking of the engine, it even came to the console. When we lifted it and looked at the lift, we saw that the upper and lower ear of the engine was broken. Don't look at it, bro. It looks like the broken pieces are here. albums / yy137 / sertan_giray_93 / 20130909_115136_zps0dbb038d.jpg Sertan 2013-12-16 19:48:05
08.05.2020 18:08 # 8
Alicilik
Thank you as soon as possible.
08.05.2020 18:08 # 9
He's using the industry,
08.05.2020 18:08 # 10
tprkozd
I had the same problem, I did not care, because of the diesel engine, but in my problem, I learned that the engine is from the lower ear.
08.05.2020 18:08 # 11
qqyyxx
For small-volume engines, there is no issue of deforming in the run, but since the 307s are in the oil care & nbsp; the air filter can be distorted even in low kms because I have inserted the ear and lowered the engine a little downward. Later, I was doing the air filter replacement by myself, with the condition of inserting the six plastic inserts, so that the ear is not deformed.
08.05.2020 18:08 # 12
qqyyxx
Unfortunately, the air filter of the 1.6s cannot be replaced without removing or wiping the motor and removing the plastic parts underneath. A complete engineering work. Though I use focus now, it is necessary to insert the gas pedal to change the pollen filter.
08.05.2020 18:08 # 13
Alicilik
[QUOTE = qqyyxx] 1.6 s air filter cannot be replaced without lowering or wiping the motor and removing the plastic parts underneath. A complete engineering work. Though I use focus now, it is necessary to insert the gas pedal to change the pollen filter. [/ QUOTE]
The pollen filter needs to be removed in the 2004 fiesta. The engineer who did it did not understand what he meant to humanity.
I heard the 1.6 air filter too, just because of the air filter they say in the service an extra 1 hour. 1.4 I like the eyes of 206 air-pollen-oil-diesel total 30 minutes maximum.
