Engine misfire
08.05.2020 20:34 # 1
Erdi123
Hi
I have a 2012 model Peugeot 207 1.4 access engine. The engine is misfire. The spark plugs and the ignition coil are changed.
08.05.2020 20:34 # 2
talip206
These problems are generally caused by coil welding. If there is already a ignition failure in the brain.Lpg, there may be a mounting error. If cables are pulled from the coil, there may be cases such as chassis, rupture etc. It is necessary to concentrate around the coil. You need to find a good electrician.
08.05.2020 20:34 # 3
Erdi123
Yes, I have a lpg in the car, my brother. He said I will look at the injectors. If he doesn't, we will turn to the engine.
08.05.2020 20:34 # 4
talip206
[QUOTE = Erdi123] Yes, I have a lpg in the car, my brother. He said I will look at the injectors.
Of course it may be, but it seemed like an electrical problem to me. Have you check the cables drawn from the coil back to lpg
08.05.2020 20:34 # 5
First of all, welcome to us. In my opinion, have the lpg electrical system checked by our friend who aspires to trouble like the electrical system. You can even pass your lpg system of the workshop to passive, take out your spell and use it in a little bit of gas, then it will be obvious.
