engine malfunction light on?
08.05.2020 19:00 # 1
crazysado
I bought my 206 xdesign 2005 model in December. Then I bought gas from opet. 2 days later, when he was going, the lamp burned. I went to my mechanic the next day, he connected the pc, asked him where did you get the gas, that the fault code came from the practice as the air flow meter, I asked him how did you get the gas from the opett, I said that he took it from the opett, he did not burn it for the last month, he did not burn it for the night, he did not burn it. I want to take that piece off. Is it possible to clean or change it? crazysado 2015-01-17 22:19:58
08.05.2020 19:00 # 2
206quik09
is it writing on the information display when the lamp is on
08.05.2020 19:00 # 3
rkalkan
.... the rkalk 2015-10-31 09:13:26
08.05.2020 19:00 # 4
rkalkan
Also, the flow meter does not easily malfunction. but if you are going to change it, something should be between 150-200 TL. As far as I know from the ford, I say, definitely do not buy sub-industry, the proper employee does not come out.
08.05.2020 19:00 # 5
crazysado
The screen only shows yellow engine light on the dial and the middle screen is only one line. It only writes radio names.
08.05.2020 19:00 # 6
Alicilik
I do not think that combustion of air activator will be related to fuel. Acismeter also do not clean, I said to clean once, I bought a new one. A very gentle piece.
