engine malfunction light
08.05.2020 19:24 # 1
fatihboz
sa urgent help. I was in a very busy traffic today. mahmutbey started to light up the car engine light at the toll and started not to pull the car. I would stand right and wait and run again. Help me please. the temperature was 93 maximum by the way
08.05.2020 19:24 # 2
Efe-Pojo
flashing is ignition failure. there may be a problem with the coil.
08.05.2020 19:24 # 3
fatihboz
the coil changed 1 month ago. I wonder if it could have stood in the air and stood in the air.
08.05.2020 19:24 # 4
Efe-Pojo
Let me repeat, if the fault lamp is flashing, it is the ignition fault. If it overheats, the fault light does not light up in any way.
08.05.2020 19:24 # 5
fatihboz
let me have a look at the coil then, could it be related to fuel, this event went on the gas after a while the gas was over there the event started there for 2 months, i'm not buying gasoline I had a dirty mixture, there was little gas that could have happened
08.05.2020 19:24 # 6
yes my teacher may have been during the transition to gasoline. shelden ninro + var doped gasoline use a bit of gasoline from it, let's see if it will do it again, if it does, it will burn due to the ignition system that friends say or the rich poor mixture.
08.05.2020 19:24 # 7
fatihboz
friends, I tried the car today. yesterday i filled 50lll gasoline bidet lpg. The same problem was in the vehicle gasoline. when it was put on the gas, it was fixed. I'm tired of going to the master now, my stomach got up
08.05.2020 19:24 # 8
akemal
If you have Pejon, you will go to the master often, man :)))
08.05.2020 19:24 # 9
fatihboz
I swear billaha we can't ride comfortably in our hearts
08.05.2020 19:24 # 10
I hope we have a month, we don't have a second, the bearing is gone, the battery is over, we got used to it. Not only for the pugs, it was previously accent - ford - megan. The best thing is to get zero, but even dacia starts from 37000 TL. :)
08.05.2020 19:24 # 11
sezar206
Thank goodness I have been going to the oil change only for 5 years. Nothing happens if you look at the vehicle. It is small, and sometimes it is things that will happen in every car. But gentle car, that's for sure. AKın descends and locks in the morning, it may cause an unimaginable malfunction.
