engine malfunction lamp problem
08.05.2020 16:53 # 1
ozkan0927
Hi friends. I am one of those who use the new 2000 model & nbsp; 206. The engine malfunction lamp on my car is constantly on. The person I received said that after the lpg was installed. and it is silent. Thanks in advance.
08.05.2020 16:53 # 2
zgr
Hello. lpgli in my car. The fault lamp you mentioned is also on my vehicle. but not constantly. If it burns one day, it does not burn 15-20 days. it did not even burn after the filter change and the lpg setting after the last LPG. however, I connect it to a computer two or three times and have it checked. Maybe it's not from lpg. I think it should be connected to the computer if it is on all the time. after all, that lamp is not placed there in vain. Connect your car to the computer to know if it is originating from lpg. Don't forget. & nbsp;
08.05.2020 16:53 # 3
ozkan0927
The person I bought was extinguished again burned. It is most reasonable to have a computer connected first. I am waiting for your advice if you have different ideas. Also I am waiting for your advice if you have a solid master in or around Istanbul. ozkan0927 2012-07-09 16:01:39
08.05.2020 16:53 # 4
ozkan0927
[QUOTE = ozkan0927] hello guys. I am one of the new 2000 model & nbsp; 206. My engine malfunction lamp is on all the time. My person said it was after the lpg was installed. I saw the lpg as a malfunction. the voice is singing and silencing 4 times & nbsp; thank you in advance.
08.05.2020 16:53 # 5
Is Oten sound beeping or something different? Does the text appear on the screen while beeping?
08.05.2020 16:53 # 6
Barut
beeping sound is usually falar doors etc. etc. when it stays on, it sounds for warning & nbsp;
08.05.2020 16:54 # 7
ozkan0927
this sound is not the sound of the door. its separate. this beep beeps 4 times and silences.
08.05.2020 16:54 # 8
ozkan0927
nothing on the screen
08.05.2020 16:54 # 9
ozkan0927
When the airbag is open, do you hear a sound? Because the sound comes from the left side where the airbag is closed? >
