engine malfunction lamp and vehicle misfire
08.05.2020 19:41 # 1
brkclb
Arkads bought a 306 xn 1.6 sedan vehicle three months ago, 150 thousand cars, the problem of deworing and the engine malfunction lamp, the radio has just changed, and the fault is still not gone, then the gasket burned out, I changed the gasket and changed the oil again, the water was reduced, the water was reduced again I did it, I was about to whisk, and now a new sot is out, mtor malfunction lamp is on.
08.05.2020 19:41 # 2
burakrak53
If the thermostat has changed its temperature sensor, there may be a problem in the pipes. or the circulation pump may be defective. If the water passes through the radiator, it means that it cannot travel inside the engine, it must be cooled. Does the radiator turn on when it gets hot so there is no malfunction in its socket. It seemed like you paid too much, I wish you would have taken a good master, who knows, maybe it was a very simple breakdown, other parts broke down
08.05.2020 19:41 # 3
brkclb
It hurts, it enters the filter in the fan, but I wait for the fifteen minutes, I wait for fifteen minutes. my carem left to write here
08.05.2020 19:41 # 4
burakrak53
When you see where you are, experienced friends will help, someone nearby can help or suggest a master who understands the job. If you ask me, is not the vehicle's radiator circulating pump failure is available in the meantime has taken the air in the master heralde? the thermostat he inserted may be inconvenient and may be incorrectly installed you should show someone who understands that the problem of heat is not something that cannot be solved. at least the system has to be identified and the fault in that system must be found first
08.05.2020 19:41 # 5
pekmez006
The source of the misfire problem is mostly the spark plug or, most likely, the ignition coil. Go to a solid master.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
