Engine malfunction lamp after 4000 revolutions?
08.05.2020 21:16 # 1
lilokan
No matter which gear the vehicle is in, after 4 thousand revolutions, the warning lamp comes on. Couldn't we solve my electricity problem? I would be glad if you help Liloan 2019-07-09 19:38:54
08.05.2020 21:16 # 2
GokhaN
diesel or gasoline of the vehicle can not lift the pressure
08.05.2020 21:16 # 3
lilokan
[QUOTE = GökhaN] cannot lift the vehicle's diesel or gasoline
My petrol coach
08.05.2020 21:16 # 4
lilokan
friends, the problem continues
08.05.2020 21:16 # 5
possibly related to the fuel system. No lpg. As far as I understand, the coil - spark plug and gas pump should be checked.
08.05.2020 21:16 # 6
lilokan
[QUOTE = sonerkyl] could possibly be related to the fuel system. No lpg. As far as I understand, the coil - spark plug and gas pump should be checked. [/ QUOTE]
Soner teacher lpg. He gives the two both. Lamp sonunce this time I try on gasoline again gives error.
08.05.2020 21:16 # 7
lilokan
don't you have friends to help
08.05.2020 21:16 # 8
ismailkaya
connect to a computer
08.05.2020 21:16 # 9
lilokan
[QUOTE = ismailkaya] Connect to a computer [/ QUOTE]
Sir, there is no Peugeot software here. Other information gives different codes in the setting
08.05.2020 21:16 # 10
lilokan
friends, my problem continues, there is a serious fluctuation in the period. Idling speed is up and down. Doesn't happen to you or have an idea?
08.05.2020 21:16 # 11
KILIC
[QUOTE = lilokan] friends, my problem continues and there is a serious fluctuation in the period. Idling speed is up and down. Doesn't happen to you or have an idea [/ QUOTE]
Have the map sensor checked, hodja.
