Engine light turns on after 307 xt lpg flicker
08.05.2020 18:00 # 1
MertMurat
2005 Engine light turns on after 307 xt lpg flicker
I have noticed that it does this only when it gets gas from different places. When the gas is low, when I cannot go to the place I constantly take, I get too little from a different place. For example, 20 TL and when the gas is low, the car is shaking, it drops from excessive pull and the engine light flashes.
I mean, if I completely empty the gas tank, then if I clean it, how would I adjust it? Why do you think this problem may be caused
I have an aerial line in my vehicle.
In addition, what kind of additive can I use in my vehicle, they say that the gas kills the car or something and they should use the additive constantly.
Actually, I am thinking about selling the situation and buying another vehicle, but I am very satisfied with the fuel :)
08.05.2020 18:00 # 2
Sertan
My teacher has almost the same problem, I have not solved it yet and it does not matter according to the gas stations. As soon as I put the car on the gas, the malfunction light turns on and the car starts to shake. But I couldn't find the solution, I use it for now.
08.05.2020 18:00 # 3
MertMurat
The problem with me is not when I go to lpg.
I suspect the gearbox
08.05.2020 18:00 # 4
cyberturk
[QUOTE = MertMurat] 2005 307 xt lpg li vibration after engine light is on
Teacher First of all, the light of the engine light goes through having a `` air flow meter '' checked, and when the air flow meter fails to perform its task, it takes less air, especially in cars working with LPG, it seems more of a problem. I had the shake in my car now it has been fixed. The solution is that there is no equipment of the inline system LPG in the engine block. Here they know that there is a digital system, the majority of which disrupts the electrical component because they touch the engine block. so you have to prevent them from touching the bottom of those apparatuses. If you prevent it from coming into contact with a hard plastic, that misfire will disappear. I hope I could tell what I want to tell.
Respects.
08.05.2020 18:00 # 5
Hakank
Hello, I had a fall and misfire on the traction, I changed the lpg filter, I made the winter setting and the problem has been solved.
