Engine lamp on
08.05.2020 20:43 # 1
Adem308VTI
Sa. Friends new in the forum I bought my first car 2008 peugeot 308 1/6 VTI engine bought auto gasoline car the next day engine lamp burned new battery was installed from it said masters then said a gas pump then they said brake brake last 3 yesterday i brought it to a master, ignition spark plug 3 is finished
Vehicle trouble
1 occasionally trembles
2 does not eat gas, when I stop and close the contact and act like a monster
The burning of 3 engine lights makes me crazy why do you think it stems from me?
08.05.2020 20:43 # 2
peugeot murat
I will help if you write the chassis number and the vehicle if you connect the vehicle to the device.
08.05.2020 20:43 # 3
Adem308VTI
My teacher says the system is faulty and the letter I comes out (risk) because I didn't get the error codes when I connected to the computer, they said it was unnecessary, but even the car was troubled in the same way today.
08.05.2020 20:43 # 4
First of all, welcome to us. Do not look at the masters, learn the error codes, a situation related to the possible ignition system appears or the catalatic collector is full, so you may encounter such problems.
08.05.2020 20:43 # 5
ggitaristt
Look, bro, I'm adjusting to people like you .. And yes I'm the friend of this forum ..
The car turned on, you got the head on him. You told him your fault, you connected it to the computer and looked at it.
The problem can be anything. You can renew the complete engine with this head.
08.05.2020 20:43 # 6
Adem308VTI
I do not understand what you are going to read, but you do not understand well, but I do not understand well. If you're not going to help you hang out elsewhere, don't answer the question I asked.
08.05.2020 20:43 # 7
ggitaristt
The master said it was unimportant, you believed how beautiful it is.
How can we help you without looking at it? Brother, you don't ride a hawk .. Every piece is electronic, every piece is connected to the brain.
You asked for help, let me help you:
Depollution system faulty .. This malfunction may be due to 29 different reasons. It means that your car cannot hold the gas mixture of air. The fault code is checked.
Oh, you want
Oxygen sensor air filter throat butterfly valve control manifold cleaning from air inlet
Float gas pump petrol hose gasoline filter gas pedal injector control from gas tank
Electric battery alternator BSI ECU sockets coil spark plug spark plug cables
Piston ring oil catalyst knock sensor manifold exhaust sensor muffler
Let's check them on the internet ..
One of them is your fault, bro .. No matter which master you go to, one of them will say it is problematic.
Arrangement: I hope there is no LPG in your car, or that system will get into the work.
ggitaristt 2018-01-09 01:41:25
08.05.2020 20:43 # 8
Please guys, no tension, we are all brothers. Smile
08.05.2020 20:43 # 9
Adem308VTI
Thank you, I will bring it to the master and look at these parts of the car. Thank you for your help.
08.05.2020 20:43 # 10
ercanayman
Hi Adam. good luck your vehicle ..
I have the same vehicle. This time last year, one of the spark plugs in my car was shaking because it was not doing its job. I changed it. I also replaced the throat butterfly, that is, the part that regulates the air setting. the problem has been solved .. I had it done in the service, it took about 300-350 something.
08.05.2020 20:43 # 11
ercanayman
I have the same vehicle. This time last year, one of the spark plugs in my car was shaking because it was not doing its job. I changed it. I also replaced the throat butterfly, that is, the part that regulates the air setting. The problem was solved .. I had it done in the service, something about 300-350 was kept.
[QUOTE = Adam308VTİ] Hour Friends new in the forum I bought my first car 2008 peugeot 308 1/6 VTI engine bought auto gasoline car the next day engine lamp burned new battery was installed from it said masters then said a gas pump then they said brake brake last 3 yesterday i brought it to a master, ignition spark plug 3 is finished
Vehicle trouble
The burning of the 3 engine lights makes me crazy why do you think it stems from me?
08.05.2020 20:43 # 12
Adem308VTI
Tomorrow, I will replace the spark plugs. Let's see if there is any problem.
08.05.2020 20:43 # 13
Adem308VTI
SA friends have changed the spark plugs of the car today, checked the machine, no problem, I bought the car, shaking the car again while going home, and the malfunction lamp will be on tomorrow, go to the master again.
08.05.2020 20:43 # 14
ggitaristt
[QUOTE = Adem308VTİ] SA friends have changed the spark plugs of the car today, it is okay to check the car, it was okay to go back to the master, and the malfunction lamp will come back to the master again [/ QUOTE]
My friend, I am trying to explain this to you. You are piecemeal.
Learn malfunction codes. Let us just look at the codes. Let's talk about the parts that may be related.
Our goal is to do what we can, and not to get money left and right, right?
Edit: Why also changed spark plugs ?? The spark plug is checked and it is understood whether it is smooth. If it is not melted, it is corrected only if it is bent. There is a reason to clean it.
ggitaristt 2018-01-10 21:38:22
08.05.2020 20:43 # 15
Adem308VTI
I'll take the codes tomorrow, brother, we'll talk to him again.
08.05.2020 20:43 # 16
308VTI2009
Hello to everyone,
In my car, the engine lamp is on and I get an antipollution error. First of all, my car is 2009 1.6Vti 308 Petrol & Lpg li.
At low revs, when I touch the gas slowly, there is a jolt in my vehicle. When the vehicle was connected to the machine, they asked for the Exhaust camshaft valve to change. P0011 and P0014 as far as I can see error codes. Both were related to the camshaft.
It looks like I'm going to change the electro valve. But I wanted to ask you, too. Thanks in advance. 308VTI2009 2018-03-26 00:31:18
08.05.2020 20:43 # 17
HasGur
[QUOTE = Adem308VTİ] new battery was installed from it, the masters said then gasoline pump then they said the brake casing last yesterday I got a master yesterday they say the spark plug is 3 finished [/ QUOTE]
If you continue to take your vehicle to those "masters"; The work goes to EGR, Turbo replacement or even the cylinder head removal and valve thrust replacements ... Do not fall into the error in the l ink I gave, some of them are cheaper than the industry for the repair of faults!
08.05.2020 20:43 # 18
ozan.JDM
Hello, I had the same problem, I had my car 106 I changed the ignition role, I checked the ignition coil, it was good at the spark plugs, I sprayed a bit of sprays on the throat butterfly, the engine lamp went out, did not vibrate, gas started, everyone has a brain diode for me, but I found the problem, this is not necessarily because it will happen when you do it an idea, of course, check it
08.05.2020 20:43 # 19
[QUOTE = 308VTI2009] Hi All,
It looks like I'm going to change the electro valve. But I wanted to ask you, too. Thanks in advance. [/ QUOTE]
First of all, welcome to us. The problem may be problematic in the eccentric reader speed sensor, which is likely to be from the valve.
