engine is leaking oil
08.05.2020 19:58 # 1
Hayrullah61
4 months before my friends bought my new 307 sw vehicle, the engine oil leak was slightly flawed during the inspection of the former owner. now in the engine everywhere in oil. What if the problem is seen from the pictures, I would be happy if you help
08.05.2020 19:58 # 2
xmen
Probably kidnapping the gasket, sir. Replace the seal is not too expensive anyway
08.05.2020 19:58 # 3
Hayrullah61
Thank you, teacher. is it okay if i think of going to paris auto
08.05.2020 19:58 # 4
madblueblacksea
It is a good idea to wash the engine a few days before you go. It's hard to pinpoint exactly where you're missing from anywhere in oil.
08.05.2020 19:58 # 5
Hayrullah61
You are right, teacher, let me do it the best
08.05.2020 19:58 # 6
GokhaN
paris peugeot maslak peugeot both are good engine washing work is good where it is running out of the way the problem of non-exaggerated oil always seals
08.05.2020 19:58 # 7
lazianke
It is possible to detect oil leak with the device
08.05.2020 19:58 # 8
Hayrullah61
I understand teacher. Do you have any advice for a suitable place to wash the engine? It is known that the pug electrical problem can go quickly
08.05.2020 19:58 # 9
ArslanBey
[QUOTE = Hayrullah61] I understand, hodja. Do you have any advice for a suitable place to wash the engine? The pug electrical problem could be quickly resolved [/ QUOTE]
What was the problem?
08.05.2020 19:58 # 10
Yusuf307
If you make it a little big problem that came from the excentric cap, you may have to look at the tip of the truck, you can open it and have the eccentric goats above.
08.05.2020 19:58 # 11
Hayrullah61
Hodja, I changed the handle gasket, there is also Di.but, my financial situation is not enough, and since it does not reduce oil, I did not dip it into the oil that leaks from the bottom. They said no need to remove Life. I said I'll have them done to change the timing of 190 thousand times. I am already doing 250 km a month. We are in 187000
