Engine Immobilizer Fault
08.05.2020 21:08 # 1
debug
Hello,
2005 206XT vehicle started this error when I pressed the ignition tonight. The contact never presses. This error appears on the screen, hands are slipping, wiper is working ... And the car is singing. Can it be a battery? Or is there a problem with the key or brain? Can we run it somehow? Or should it be necessary? If you are looking for such problems around Istanbul Tuzla, it would be perfect if you write it down as you know :)
08.05.2020 21:08 # 2
okaNStarss
the jack of the immo module in the contact should not be removed
08.05.2020 21:08 # 3
debug
The problem was with the battery :) Even the battery did not transmit because the pole head made oxide. I changed it improved. Now my question is that the central lock does not work. Does anyone know how I can introduce this again?
08.05.2020 21:08 # 4
Does the central lock not work at all or does it not perceive when it is made of sand?
08.05.2020 21:08 # 5
debug
No, only the control does not work, all the doors are locked when locked with the key :) the battery is gone or not. Once again, the battery was exhausted, but then a keymaker took care of it.
