engine hood or engine hood
08.05.2020 18:35 # 1
griaslan
hello 206 hdi i have x-line vehicle which do you think reduces the most? mtor hood cover or engine cover
08.05.2020 18:35 # 2
herry
hood seal reduces noise.
08.05.2020 18:35 # 3
griaslan
[QUOTE = herry] hood seal reduces noise.
[/ QUOTE] I asked if there is a vehicle in your car, they said 200 TL I hope it will be useful
08.05.2020 18:35 # 4
herry
It came as a factory outlet in my car, but it got very dirty over time, so I disassembled it. I know I asked 200 lira in the industry, they said, I have not bought yet. I will think again when I leave for maintenance. I can say that as someone who has used both kinds of sound, the sound is very noticeable. Get it if you have budget.
08.05.2020 18:35 # 5
barishrocker
They also use it for sound insulation. Also, there is a firex on the same site, the fireproof acoustic sponge..the felt of my vehicle is solid, I applied it to the trunk ..
http://www.adetasyapi.com/?=/bituself_oto_ses_yalitimi_-_bituself_oto_ses_ızolasyonu/&urun=1555 ">
barishrock is 2014-06-04 23:25:14
08.05.2020 18:35 # 6
Mesut48
I have a problem with my forum, I can not understand, there is a problem, click the link opens this topic again.
08.05.2020 18:35 # 7
aslanaft
[QUOTE = Mesut48] I have a problem with my forum, I couldn't understand my forum, click on the link, it opens this topic again. [/ QUOTE] the same happens with us :) mrb I put on the cover yesterday it even reduced the sound incredibly but I will do it under the hood myself
08.05.2020 18:35 # 8
barishrocker
Then let me say, copy and paste the link into the browser;)
08.05.2020 18:35 # 9
barishrocker
This can also be used. I tried, it doesn't burn with lighter, it just melts and flows.
http://www.adetasyapi.com/?=/duz_yapiskanli_yanmaz_akustik_sunger_1_cm/&urun=943
08.05.2020 18:35 # 10
aslanaft
[QUOTE = barishrocker] This can also be used. I tried, it doesn't burn with lighter, it just melts and flows.
http://www.adetasyapi.com/?=/Duz_Yapiskanli_Yanmaz_Akustik_Sunger_1_Cm/&urun=943üldü/QUOTE] I am also investigating the inside of the doors, trunk and back floor whenever I have spare time, I will dismantle the car all the time, it will shake every side of the car and to avoid the asphalt noise. I think it is a must
08.05.2020 18:35 # 11
barishrocker
Then you need to insulate early. Then you stick an acoustic sponge on it.
You can examine what I did to the vehicle ..
http://forum.peugeotturkey.com/forum_posts.asp?tıd=32535&pn=3&title=peuget-307sw-16hdi-sessistemi-izolasyon-detailing
08.05.2020 18:35 # 12
aslanaft
[QUOTE = barishrocker] Then you need to isolate early. Then you stick an acoustic sponge on it.
http://forum.peugeotturkey.com/forum_posts.asp?TID=32535&PN=3&title=peuget-307sw-16hdi-sessistemi-iz insulation-detailinghür/QUOTE] brother 4 you have done 4 work, the master work has been done in the master plate koçtaş. It would be great if the sponge was made on this material.
08.05.2020 18:35 # 13
barishrocker
You cannot find it in Koçtaş. There are friends who buy and sell from the wholesaler. Let me give your phone if you want, get in touch. Apart from that, the teroson sp100 does the same.
08.05.2020 18:35 # 14
barishrocker
Erkurt alone is quite enough, but if you make an acoustic sponge on it, it becomes a monster.
Ad and phone are here:
http://www.caraudiohifi.com/forum/index.php?topic=2267.0
08.05.2020 18:35 # 15
aslanaft
[QUOTE = barishrocker] You cannot find in Koçtaş. There are friends who buy and sell from the wholesaler. Let me give your phone if you want, get in touch. Apart from that, the Teroson sp100 does the same job.
08.05.2020 18:35 # 16
barishrocker
[QUOTE = barishrocker] Erkurt alone is quite enough, but if you make an acoustic sponge on it, it will be a monster.
http://www.caraudiohifi.com/forum/index.php?topic=2267.0[/quot A]
In the previous message, there are details and phone in the link, but I sent you a message again ..
