engine fault stop lamp (Solved)
08.05.2020 15:41 # 1
celllat
friends yesterday, I added hydraulic oil, brake fluid and anti-freeze to my vehicle, and when I switch on and start the ignition, the stop lamp stops flashing after a while stops flashing.
What could be the reason and is it important?
I may have put it too much, does it harm?
I expect help from experienced friends: ((
(I'm talking about the text that says stop under the indicator)
celllat 2011-06-25 18:33:27
08.05.2020 15:41 # 2
kenan_gul
it burned in me too, the light flashed and then it was fixed then it was constantly lit .. a problem of temperature ... or a warning light for a similar problem ... it ..
08.05.2020 15:41 # 3
celllat
wrongly understood a warning lamp that says stop, not a lamp in the shape of an engine.
08.05.2020 15:41 # 4
kenan_gul
yeah ... I also have that light next door ... the lamp burning for fever ... there was a problem with the mugs ... was it related to our antifreeze? i have no idea that we are alone ...
08.05.2020 15:41 # 5
In short, if the vehicle has a malfunction, whatever the name of the malfunction, that light will be on :)
08.05.2020 15:41 # 6
kenan_gul
[QUOTE = facemelowe] In short, if the vehicle has a malfunction, whatever the name of the malfunction, that light will be on:) [/ QUOTE]
service cukkk die cosuyo problem ... :)
08.05.2020 15:41 # 7
[QUOTE = kenan_gul] [QUOTE = facemelowe] In short, if the vehicle has a malfunction, that light will be on whatever the name of the malfunction:) [/ QUOTE]
service cukkk die cosuyo problem ...:) [/ QUOTE]
solves it but takes what it takes, so they're looking at changing it right away, they never go to repairs.
08.05.2020 15:41 # 8
celllat
[QUOTE = kenan_gul] yes ... I have that light side ... the lamp burning for fever ... there was a problem with the mugs ... was it relevant to our anti-fire?
Thanks for the cvp, then it is not important.
08.05.2020 15:41 # 9
sercinho
it is not that important, it flashes 3 times after it runs then it ends completely
08.05.2020 15:41 # 10
celllat
We are antifreeze and I have no problem before I put the hydraulics, but let me go to the service.
Thank you for your CVs.
08.05.2020 15:41 # 11
sercinho
If you share the source of the problem after it has been rolled out, it will be beneficial for friends who come to the press later.
08.05.2020 15:41 # 12
tilbe307
The master said to me, I told him this complaint, because the handbrake was pulled out, it flashes, so he said I said tamm !!!
08.05.2020 15:41 # 13
Kemanyak
Lower the hydraulic oil level to below max. (brake fluid)
08.05.2020 15:41 # 14
celllat
[QUOTE = Violin] Reduce the hydraulic oil level below max. (brake fluid) [/ QUOTE]
Yes, I dropped the level of the hydraulic oil as I said yesterday when I got off the road to take the car to the service this morning, and when I started the car in the morning, the problem disappeared. thanks bro.
So it was caused by hydraulic oil.
The problem has been solved.
08.05.2020 15:41 # 15
Come on late ...
08.05.2020 15:41 # 16
let's say it is past then plus your eyes are bright
08.05.2020 15:41 # 17
oguzhan29
get well my brother it wasn't a big thing
08.05.2020 15:41 # 18
thyateria
The same fault occurred in my 201 model 306 sedan car,
At first, the stop lamp was on, then the temperature indicator started to end,
The radiator was reducing water, I replaced the complete radiator and fixed the error,
Thyateira 2014-11-24 08:45:21
08.05.2020 15:41 # 19
ihtiyaR
Greetings, thank you for your sharing, the same problem happened with me. Antifreeze Oil, etc. I changed it, then the stop signal and additionally the signal started to burn, then it burns at the first start, then it is gone, probably the brake fluid is similar or it is not the same.
