Engine fault light is on and stopping in every gear |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 206+ | |
| 08.05.2020 20:32 | # 1 |
I use the 2010 model peugeot 206+ diesel one. Regardless of the gear of the car, it stops at every revolution and the car fault light is on Whichever master I took, one says the sensor and the other says it has a pressure seal on the pump. Even when idling, the car suddenly rises and stops and does not start, but after resting the car for 5-10 minutes, I would like your help on the subject. |
| 08.05.2020 20:32 | # 2 |
sonerkyl |
[QUOTE = raptorsecond] Hello bro, my brothers, I use the 2010 model peugeot 206+ diesel one. Regardless of the gear of the car, it stops at every revolution and the car fault light is on Whichever master I took, one says the sensor and the other says it has a pressure seal on the pump. Even when idling, the car suddenly rises and stops and does not start, but after resting the car for 5-10 minutes, I would like your help on the subject. [/ QUOTE] First of all, welcome to us. Doesn't give an error code when connected to your computer, I think the vehicle should give it, but obd vehicle fault reader devices without the original peugeot software cannot read some error codes. I think the problem is like the eccentric shaft and the crank speed sensor.
