engine fault light :)
08.05.2020 15:41 # 1
tilbe307
friends the other day I cleaned the throat butterfly yesterday I made the lpg calibration. As a result, the engine malfunction lamp went out. Is it normal like a joke? Dil Çıkarma
08.05.2020 15:41 # 2
tilbe307
Let's always share the problem, look at the car, the problems disappear :)
tilbe307 2011-06-24 18:25:17
08.05.2020 15:41 # 3
d3Li
When the building gets gas again or after driving, it doesn't burn again.
08.05.2020 15:41 # 4
tilbe307
it was already burned, it was giving antipolition fault error.
08.05.2020 15:41 # 5
metin
[QUOTE = tilbe307] friends the other day I cleaned the throat butterfly, yesterday I got a lpg calibration. As a result, the engine malfunction lamp went out. Is it normal like a joke? Dil Çıkarma [/ QUOTE]
I think normal.
08.05.2020 15:41 # 6
I think the normal ins won't do it anymore, let's hope
08.05.2020 15:41 # 7
If the friends settings are correct, the fault light will not be on. I said this in a very matter, let's say it again ...
08.05.2020 15:41 # 8
metin
[QUOTE = CeCoLi] Friends if the settings are correct, the fault light will not be on. I said this in a very matter, let's say it again ... [/ QUOTE]
I think that the friend's setting is correct, because of the institutions formed over time, the air-fuel mixture ratio has changed and its light is on, and when it is cleaned, it turns off because it has become obsolete.
