ENGINE FAULT LAMP PROBLEM
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 208
21.08.2020 12:37 # 1
fotomon12
HELLO GOOD DAY, I WISH MY CAR LIGHT IS LIGHT ON MY CAR, WHEN I CONNECT IT TO THE COMPUTER, IT WRITES U1213 AND P2127 PROBLEM. WHEN I SHOW THE ENGINE, THE LAMP DOES NOT TURN LIKE THE ENGINE HOUR HELP PLEASE ..
21.08.2020 20:27 # 2
ismailkaya
What is the engine type of vehicle?
28.08.2020 23:51 # 3
fotomon12
1.4 hdi
30.08.2020 18:47 # 4
beylulb
mrb 2005 model 307 1.4 xr lpg li there is no problem in gasoline, but when it switches to lpg, it makes a misfire in the re-idle state, it almost comes to a stop and even stops and the engine fault light is on. I got in gasoline a little bit and made the gas adjustment again. It is not compatible with lpg. It is not compatible with lpg. It is not only compatible with peugeot. There are so many LPG vehicles in traffic. It continues the same again. This makes it uneasy, we do not understand whether we need to wait for our feet in the gas so that it does not stop. Can you help me?
31.08.2020 16:30 # 5
ismailkaya
We have bendede the same car 2 years 10 friends worked on this engine and LPG can we solve the problem 98% LPG can run smoothly in Turkey can not help you other than this 10kisi you live in which province I help art 1.4 16V 90hp. Engine type 0535-067-40-60 İsmail kaya
02.09.2020 11:09 # 6
beylulb
I live in Kayseri. Sometimes I think about whether it is an alternator. The problem increases even more when using functions such as fan, headlight air conditioner.
02.09.2020 21:28 # 7
ismailkaya
Not from the alternator, yes, the air conditioner headlights fan will have trouble when you turn the steering wheel where it stops.
