engine fault lamp hk ..
08.05.2020 17:10 # 1
Ibrahimb
Hi friends;
I have a 2002 model 307 xt triptonic .. When I use my car in LPG, it gives Antipollution Fault failure and the fault lamp is on. But when I use gasoline, the lamp turns off automatically after 1-2 km. When I ask the service, he says that there is no important situation .. I also got off work on Saturday evening at 16:00. After going 500 meters, while the gear that I will set off on the main road falls from 4 to 3, a letter called aotomatic gearl faoul appeared and locked the gearbox. The vehicle did not pass the manual. I called my friend immediately, stop, he said, run it better, he said it was okay. Now I called the service, the room said the same thing. ? Or did something happen to you?
I'm waiting for your return.
08.05.2020 17:10 # 2
Ibrahimb
friends that I have not experienced this problem other than me? request and idea please ...
08.05.2020 17:10 # 3
Serkan
Antipollution Fault error is generally related to poor quality fuel, this warning appears on most peugeot, especially for those with lpg, take a look at the following topic
http://forum.peugeotturkey.com/forum_posts.asp?TID=22961&title=antipollution-fault-hatas Reviews
08.05.2020 17:10 # 4
Ibrahimb
Let me open the LPG settings a little bit, then let me take LPG from a fixed place as friends say ..
thank you ..
