Engine fault lamp ..
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 15:07 # 1
savatafatih
Hi ,
My vehicle is 406 2000 models. Sometimes when the vehicle is going, suddenly the stop light comes on and starts to sing.
At the same time, of course, the engine is overheated on the computer screen, it says in English.
I don't know, but the temperature of the engine is almost exactly over 90.
In another friend's vehicle, it is still under 90. I wonder if it's getting too hot from lpg, but mine is not the only LPG vehicle. I don't know .. The car is very beautiful, but if those shortcomings are eliminated, it will be more beautiful.
Goodnight..
08.05.2020 15:07 # 2
[QUOTE = savatafatih] Hello,
Goodnight..
If you experience this event shortly after starting your vehicle, the sensor that probably has the coolant temperature of your vehicle has malfunctioned.
Koliva 2011-02-25 00:31:10
08.05.2020 15:07 # 3
savatafatih
[QUOTE = koliva] [QUOTE = savatafatih] Hello,
Goodnight..
rather than shortly, usually after a while ..
but not always. It's going to be short, two or three times.
Tşkler.
08.05.2020 15:07 # 4
Tşkler.
If the warning passes after continuing a little, there is air in the coolant. Have you just changed the water of your car?
Koliva 2011-02-25 00:37:32
08.05.2020 15:07 # 5
savatafatih
Yes, the radiator has changed. Juice oil has changed a lot. Maybe as you said. We need to look..
08.05.2020 15:07 # 6
[QUOTE]
[QUOTE = savatafatih] If the warning goes on after some continuing, there is air in the coolant. Have you just changed the water of your car?
If you know the bleeding location, you can do it too. Probably there is a screw on the pipe near the thermostat somewhere at the top of the radiator. In this way, you can get the air, but usually there is another tool in the masters for this job. They operate by installing a funnel instead of a thermostat.
