ENGINE FAILURE WARNING WHEN COMPRESSING THE VEHICLE
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 308 (After 2014)
25.06.2020 08:09 # 1
SeAsToo
Hello, I have a problem that has happened to me for 3 times and I have overcome the risk of accident, my vehicle is a problem in normal cruising, so there is no problem if I go calmly, but whenever I need power, it gives an engine failure warning at speeds (about 150km) and a situation like the turbo does not work. 110km speed does not exceed, when I stop and start the vehicle, it returns to its original state, but the light continues to turn on for a while. I went to the service related to the problem, the service said that it gave a turbo pressure failure and that the solution would be electro valve replacement, but when I talked to a few people who experienced this incident, they said that the same part was changed but the problem was repeated, and within the scope of the + warranty, TURBO, CATALYST and a few parts were covered by warranty. They changed my vehicle, there is no guarantee.
25.06.2020 09:14 # 2
First of all, welcome to us. The service said, we can say true, professor, these types of problems are usually caused by the turbo electrovalve. High speeds are more common. It would be nice if you could learn the exact error code. It would be nice if there was a guarantee, but it would be very costly if you try to make the parts yourself. t9 chassis which engine is there, my teacher, 92 hp hdi - 112 e-hdi - 120 bluehdi motormu
25.06.2020 09:38 # 3
SeAsToo
Can I solve it with customer service, which is 120 hp, I got 2 hands, I go to the service, I hope it is solved with an electro valve.
25.06.2020 12:27 # 4
Call bluehdi motor and see my teacher, when the last time you need to learn about the vehicle that has been serviced in the authorized service, if 1 maintenance has passed, something can be done by forcing it again.
25.06.2020 13:00 # 5
SeAsToo
Lastly I took it for maintenance and finally I went for the traver problem. They solved the traverse problem, I hope they solve it too.
25.06.2020 14:47 # 6
By calling the peugeot center you can get an extra discount if the service is well-maintained. They can give a discount of around 40 - 60%
