Engine Ear Problem
08.05.2020 19:09 # 1
rules52
Hello friends, 2013 model partner Tepe Zenit bought a car 1 year ago, had a great driving pleasure, silent. After 8,000 voices started to come, the service made the ear of the motor is getting better with lubrication. I did not accept it. How healthy is the lubrication process in your opinion
08.05.2020 19:09 # 2
baybaba
What harm can come from lubrication, let them lubricate, if the problem persists, you will replace it, but only 2 years
a problem that should not be in a vehicle,
08.05.2020 19:09 # 3
BLACK LION
rules52 If you suddenly hit the gas on the way, it should change if it makes a hard knock, or if it makes a flickering knock on the hill. The tires of these ears do not rot so soon, but take a look. If their tires have tears, they should be replaced. If this is not what I said, give it a try if it will be greased as they say.
BLACK LION 2015-03-13 04:02:57
08.05.2020 19:09 # 4
samet206
It is not much to change if there are problems in the ears. It does not make sense to produce workarounds for what to do with lubrication.
08.05.2020 19:09 # 5
rules52
Hi friends, after a short correspondence, the problem was solved. More than 3 bikers recommended that the tire break down after lubrication.
I made correspondence with peugeot using social media and the engine ear has changed smoothly! rules52 2015-04-06 14:25:34
08.05.2020 19:09 # 6
oguzhan29
you did the best it makes the most sense to change
08.05.2020 19:09 # 7
DarkSilver
[QUOTE = rules52]
I made correspondence with peugeot using social media and the engine ear has changed smoothly! [/ QUOTE]
So even for this, they are trying a ton of people.
08.05.2020 19:09 # 8
get well soon. yes, a replacement from warranty is like ditching a camel in services. I'm glad your problem got resolved.
