engine ear?
08.05.2020 19:14 # 1
muhammed.ceyhan
Hello friends. With my 206 vehicles, I entered the workshop very hard this evening. Afterwards, when the engine was running, it started to jerky and loud, and when I pulled my foot out of the gas while the vehicle was in gear, it started to feel a rattling sound (similar to the sound of water). I was favored with engine ear and engine mounts. Could it be broken? I wanted to get your opinions. Could it be for these reasons? If it has anything to do with this, I will travel from Ankara to Kocaeli tomorrow. Do I have any problems on the road?
Thank you in advance.
08.05.2020 19:14 # 2
muhammed.ceyhan
Eyallah friends. Thank you very much for your help.
08.05.2020 19:14 # 3
vpro
The car vibrates at idle, even if it is from the engine's ear or a jewel, it is like hitting too much gas and knocking when pulled.
08.05.2020 19:14 # 4
xmen
if there is an excessive vibration in idling, it is the engine ear ...
08.05.2020 19:14 # 5
muhammed.ceyhan
There is a sound like a squeal in the rolentide. I record and put a voice record today
08.05.2020 19:14 # 6
Get well before you set off, if you look at your master, it will be better for you and you will be comfortable. After all, we go on 4 wheels.
08.05.2020 19:14 # 7
talip206
http://forum.peugeotturkey.com/forum_posts.asp?tıd=38222&kw=%fe%fdk%fdrt%fd&pıd=535100&title=motor-egzos-titremesi#535100
I searched a little and the most logical came from the disruption of the valve setting. In general, the chirping sound was either due to the air in the radiator or from the valve setting. Because of your story of getting into the hard case, Your situation seems to fit the valve. Look at the ears of the engine.
