Engine drains water
08.05.2020 20:10 # 1
niklaus
Hello friends, I used the car for 10 km in the morning and the engine's antifreeze engine water was dripping on the ground, probably 1 liter flowed to the ground dropwise. I added water, then I used the car for about 50 km. The car did not pour 1 drop of water. The master says the pipe hole, but the car is not pouring water. If there is a hole in the recirculation pipe, do you make a situation like not letting it flow? or is the problem in another place?
08.05.2020 20:10 # 2
Oktkor
My engine had also thrown water then I had researched it. If it is used with water, then if it is used with antifreeze, the antifreeze dissolves the parts of the water that are eroded. Drips or cracks etc. occur in those parts. Then, when water is added again, the water oxidizes and closes those parts again. It is rusting again.
This was what I was told.
My humble idea is that if you did not remove the car on the fiber, look elsewhere, do not rely on the master like me and do not double the cost.
08.05.2020 20:10 # 3
niklaus
Thank you I will consider for your comment
08.05.2020 20:10 # 4
JunioR56
If you used the tool by squeezing it, it may have extended the hose from the pressure for a while and drained the water through a capillary crack. If you have a loss problem, I think you should cut all the hoses.
In my car, water is decreasing, I couldn't find it for 2 years. I said let my head be comfortable. I went to his own mechanic for my friend's car, I asked the informal old man about his problem, he was missing the lpg hose. I used the 500 km gasoline, the car is a master I will call zero reduction, there is a master.
08.05.2020 20:10 # 5
r32
I had a similar incident, my brother, the water was missing, I completed 50 - 60 km, I pulled in front of the house, when I cooled, I looked, there was no reduction. 2 * day lay down the car Day 3 The water was reduced by 1 liter radiator drilled. I have compelled it to run out of water in a place where it is not possible.
08.05.2020 20:10 # 6
niklaus
Thank you, friends, when I have the opportunity, I will try to find the leak and remove it.
08.05.2020 20:10 # 7
In my focus, it was where I found it where I missed it in a sunny and warm weather.
