Engine Coughs To Gas Fast Pressure.
08.05.2020 13:59 # 1
ENGINE COUPLES WHEN GAS PRESSED (No Engine Hood) An explosion is seen when the engine is suddenly pressed to gas, or if sounds similar to cough sounds are heard, this may be due to the grab assembly in the carburetor and the malfunctions listed below. In the carburetor: 1- There is a hole in the grab pump piston or diaphragm. 2- The snatch pump course is very short. 3- Grab pump ducts are clogged. 4- The snatch pump misses the valves. 5- Volatility of gasoline is too little or too much. 6- Float adjustment is very low. 7- Fuel pump pressure is too low. 8- In the carburetor, which has a steam discharge valve (antiperculator), the steam discharge valve opens before the throttle closes. In this case, when the gas is pressed while the engine is hot, there will be no snatching in the engine. 9- Since engine and air are very hot, there is a possibility of steam buffer in gasoline. (Look at the steam buffer bet). 10- In the carburetor; if there is a power needle acting with the throttle connection arm or the vacuum piston, there is an adjustment, jamming or clogging of the vacuum channels in its operation. 11- If the carburetor has a vacuum operated power flap, there is a malfunction, congestion, leakage in the vacuum piston or blockage in the ducts in the partial throttle opening and medium speeds. 12- Ignition time setting is very delayed. WHEN THE GAS IS PRESSED THE ENGINE SINGERS If the engine runs smoothly at idle, the engine is singling when the gas is pressed while the car is in motion; The malfunctions listed below cause the ignition to cease due to the high compression. Ignition is weak. 2- Spark plug gaps are very clear. 3- The spark plug is dirty or wet. 4- Spark plug porcelain is internally defective. (SHARED FROM MY COURSE NOTE TO YOU) MELİH2008-12-04 13:31:28
08.05.2020 13:59 # 2
Subject: Moved to the section `` FAILURES AND SOLUTIONS ABOUT YOUR PEUGEOTS ''.
08.05.2020 13:59 # 3
Ismail
Thank you for the information
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
