ENGİNE COOLANT TEMP TOO HİGH
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 16:53 # 1
AnkaraLi
Sa
First of all, thanks to everyone for the useful information and sharing here. I request the help of a friend who owns it. Thank you
08.05.2020 16:53 # 2
Hello,
Do you have antifreeze in your vehicle? How did you check the water level?
Please click on the link in my signature section and introduce yourself. Thanks. Reviews
08.05.2020 16:53 # 3
jack67
When your vehicle's engine temperature has increased, if there is a warning like this in idle, there is a problem in your temperature sensor.
08.05.2020 16:53 # 4
AnkaraLi
The water level does not decrease the normal water, I looked at the circulation hose, it was not warming up & nbsp; I solved it, there was congestion, I opened it. writes and ENGİNE COOLANT TEMP TOO HIGH alert appears & nbsp;
08.05.2020 16:53 # 5
look at the thermostat.
08.05.2020 16:53 # 6
[QUOTE = AnkaraLi] Water level does not reduce water normal water, I looked at the hose, did not warm up, I did not know if there was an antifreeze. I am normal now. some time after it comes, it says stop and ENGİNE COOLANT TEMP TOO HIGH warning comes out & nbsp; [/ QUOTE]
Make sure you have antifreeze in your vehicle. If there is no antifreeze, the likelihood of such problems will increase even more. Simply put, if the water in the container where you put the coolant is colored, there is antifreeze. Of course, the rate is important, but at least you learn that it exists. It is recommended to replace it every two years.
It seems to me that your thermostat is off. In other words, the thermostat does not open so that the water is recirculated. Reviews
08.05.2020 16:53 # 7
AnkaraLi
Thanks for the information you provided, I will have a look at what you have said today. I hope nothing will come out of the antifreeze or the thermostat.
08.05.2020 16:53 # 8
[QUOTE = AnkaraLi] Thanks for the information you provided, I will have a look at what you have said today. [/ QUOTE]
The possibility of doing so is directly due to lack of antifreeze. However, in the absence of antifreeze, there are a lot of points to look at.
08.05.2020 16:53 # 9
tellotello
Teacher Koliva, what should be the color of antifreeze? Is there a common color? I would be glad if you can inform. & Nbsp;
Good day ...
08.05.2020 16:53 # 10
[QUOTE = tellotello] Koliva teacher, what color should the antifreeze be? Is there a common color? I would be glad if you can inform. & Nbsp;
Good day ...
Every manufacturer produces antifreeze with a unique color. So it is not right to stick directly to the color. In general, those that contain inorganic acid are green, and those that contain organic acid are orange / red. It is necessary to know the active substance inside by looking at the box of the antifreeze taken. However, it can be understood that it should be changed in a few years or a few kilometers. Reviews
08.05.2020 16:53 # 11
tellotello
But is it enough to look at the tank where we put the coolant to understand the amount of antifreeze in the vehicle, or at least whether it is available? My warehouse looks yellow from the outside, would I want to comment if I take a photo of it tomorrow? Thanks for the help.
08.05.2020 16:53 # 12
You can tell whether it exists by looking at the cooling water tank. It can be yellowish or greenish antifreeze water. But you cannot understand whether it is sufficient.
08.05.2020 16:53 # 13
djchaos
I have heard that the red antifreeze is used for the new generation vehicles, because the red organic is still our masters here know the best. and never drive your vehicle in summer or winter without antifreeze. djchaos 2012-07-05 00:30:27
08.05.2020 16:53 # 14
I also have the red color. The degrees of freezing and boiling are better than green. Thanks to our brother Ayykut shared important information on this subject as well as everything. For example, green and red antifreeze should not be mixed. and this causes the pipes to clog and cause heat.
08.05.2020 16:53 # 15
True, friends. It is a newer technology product which is red / orange. Service maintenance is 5 years, not 2 years like the others. Green, yellow, gold color etc. those who say we can say 2 years. & nbsp;
08.05.2020 16:53 # 16
AnkaraLi
The problem is solved. Thanks for the information you provided. I changed the thermostat dead output, I forced the engine as close to 1 hour on the highway as I could but I had no problems. Thanks again.
08.05.2020 16:53 # 17
Get well soon.
