Engine coolant air (Resolved :)
08.05.2020 15:52 # 1
semsword
I guess that there is air in the engine coolant and that if I do not exhaust too much air in this heat, it will do bad work for me. In the picture, are the screws next to the green socket for this job? Does anyone have advice on how to get the air off?
semsword 2011-07-26 17:11:36
08.05.2020 15:52 # 2
metin
I must say that if I saw the brother did not come out clearly, I am not sure if he did not know the 206 engine. If it was 307, I would say its location.
normally it is on the water pipe that enters the taster or leaves the radiator. By loosening the screw on it, you wait until the water comes, so it is taken. The place has to be in a simple, easy place.
I think those green sockets are power cord. so I don't think he'll be there.
08.05.2020 15:52 # 3
berk2309
As far as I know, there must have been screws but I'm not sure
08.05.2020 15:52 # 4
I could not completely get out of the picture, but it can be found by being described. It is on the hose that enters the radiator and is usually black. Before loosening the screw, start the vehicle and make sure the heater is fully open. Then loosen the screw and drain the water until the air bubbles are gone. At the same time, show the coolant reservoir to prevent the water from falling too low. If it drops, add coolant.
08.05.2020 15:52 # 5
The picture is water:
08.05.2020 15:52 # 6
semsword
Thanks ... I can look at an experience in the evening ....
08.05.2020 15:52 # 7
metin
You took my picture of koliva, naptin how do I find it, how would I describe that piece (:
health into your hands.
08.05.2020 15:52 # 8
[QUOTE = text] You took my picture of koliva, how did I find it, how would I describe that piece (:
There is a ready film Kahkaha
08.05.2020 15:52 # 9
The right side of the engine is the thermostat box. There are 2-3 mugs on the top and the hose comes out from the top, etc. ... there is an air intake area on top of it, as the boiler shows on the heater hose ...
08.05.2020 15:52 # 10
[QUOTE = CeCoLi] is the thermostat box on the right side of the motor. There are 2-3 mucus on top and the hose comes out from the top, etc. ... there is a bleeding place on top of it.
This is also an option. The picture is also here:
08.05.2020 15:52 # 11
goktug
Is that the picture in 307 above?
08.05.2020 15:52 # 12
1.4 hdi did you have any engines on it?
08.05.2020 15:52 # 13
metin
[QUOTE = göktuğ] is that the picture in 307 above? [/ QUOTE]
The dipstick looks like the first painter. if it is 206, here is 206.
08.05.2020 15:52 # 14
semsword
Could these screws be according to Cecoli?
semsword 2011-07-20 13:44:04
08.05.2020 15:52 # 15
08.05.2020 15:52 # 16
metin
[QUOTE = semsword] Could these screws be according to Cecoli?
I don't think the screw will stand that way.
it makes more sense to look upwards for comfortable intake of air. it is on the main pipe leading from the radiator to the engine.
08.05.2020 15:52 # 17
My car is also standing next door. a small allen-headed yellow metal bolt on the bend ...
The rubber valve cap on the other side of the heating hose. Keep in mind that you always have your valve cover with you. If one burst of this valve bursts, you will need a new one. If there is no valve on the top of your running tires, no problem.
It exploded as my father went by car. Suddenly, as the vapors escaped, the antifreeze smelled. We stopped immediately. While we were thinking as if a pipe etc exploded, we looked at it and the head of the valve was spraying with broken water. I got it from the tire right away, I bought it, I got it, heat it :))
the cecol 2011-07-20 15:37:05
08.05.2020 15:52 # 18
metin
Yes, when it is plastic, it can be thrown away in the heat. cem bro you were lucky. Those who do not fit the valve will be napped (:
08.05.2020 15:52 # 19
semsword
I just said I could not take the air of the car, I removed the two screws, I waited, I waited for 10 minutes or so. I am waiting for your suggestions, not anywhere else.
08.05.2020 15:52 # 20
How long was the temperature indicator?
Page : / 2
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
