engine click sound (video added)
08.05.2020 18:23 # 1
bjkamil
my friends vehicle is 206 1.4 petrol. In 134 thousand. Last year, I made the valve adjustment, but the noise of the vehicle's engine sounds. Could the valve adjustment be impaired? they ask why those who hear the voice of the vehicle work like this.
when the engine is hot;
bjkamil 2014-03-18 19:17:26
08.05.2020 18:23 # 2
Serkan
I can not say anything about sound, but it is normal to burn 10 LT in Istanbul.
08.05.2020 18:23 # 3
It is normal to burn 10 liters in winter, but it is necessary to listen to the engine creaking, even the sound coming from the belt you call clack can be
08.05.2020 18:23 # 4
tetik-soner
I think he can listen to the strap.
08.05.2020 18:23 # 5
renk1234
Failure to squeeze the gasoline vehicle may cause the camshaft chain belt valve and injector
08.05.2020 18:23 # 6
bjkamil
the sound is coming under the vehicle. sound is more pronounced when the engine is cold. The sound of the belt is not as sharp as the valve sound. Are there any umraniye or bostancı you recommend?
08.05.2020 18:23 # 7
emirhan307
It is able to relax because of the valve setting.
08.05.2020 18:23 # 8
ahmed206
Last year, I also had a valve adjustment and a timing change, once every two months, I hear a click and suspect these two operations. Let's share our experiences. There is an acquaintance in İçerenköy industry, maybe it can guide you. Let me ask Facebook if he has any.
08.05.2020 18:23 # 9
murat222
2 weeks ago, I changed the valve, cut off the trim, if the setting is broken, if you say that the car ramps down in the low gear, the setting will escape ....
08.05.2020 18:23 # 10
ahmed206
So the engine brake I do sometimes causes it?
08.05.2020 18:23 # 11
ender.t
My teacher has a creaking sound in my car. The car 307 does a lot when it is cold, it decreases when it is hot, it even turns normally. this event may be related to the part we call lifter, because our vehicles make the valve adjustment with oil pressure. When the car gets hot, the oil stops when it gets up, but when the car cools, it leaks the oil again and it becomes neat until it gets hot. In other words, adjusting the valve may be a short-term solution, but I think that this adjustment will be impaired again as the lifter will make it while the vehicle is running.
08.05.2020 18:23 # 12
ahmed206
I think it makes sense, but 16 valves and 8 valves are separate.
I'll still go, master. How much do you think the valve adjustment? let's not kiss then
08.05.2020 18:23 # 13
ender.t
[QUOTE = ahmed206] I think it makes sense but 16 valves and 8 valves are separate ..
Vehicles with instructor lifters do not have valve adjustment. yours is no different, I guess there are 8 lifter.
08.05.2020 18:23 # 14
bjkamil
very cold sound in my car when it is more like click-to-click. When it gets warmer, the sound decreases, but still annoying sound is heard. In the evening, I will shoot the video when the engine is cold and hot and throw it here.
08.05.2020 18:23 # 15
ahmed206
No, I don't have a lifter, because I know the valve was adjusted last year.
08.05.2020 18:23 # 16
okankrgz
If your vehicles are hydraulic and there are noises called 'clicks', I recommend you to practice as follows.
1. Change the oil urgently (usually 10/40 is used in Peugeot, I recommend elf, castrol, mobil)
2. Replace your oil filter in case of sound interruption
3. If the sound is still present, open the sump to check if the oil pump strainer is clogged, clean,
4. If the sound still continues, check if your oil cooler is working,
5. If there is still sound, last resort lifter will be changed.
08.05.2020 18:23 # 17
bjkamil
I suggest you to practice as follows if your vehicles are hydraulic, and there are voices called as "click" in your [QUOTE = okankrgz] vehicle.
oil, oil filter changed in winter maintenance. but this voice has been around for 2 years. I don't know if there is a lifter in my vehicle.
08.05.2020 18:23 # 18
bjkamil
videos added. (in my first message)
08.05.2020 18:23 # 19
ahmed206
It sounds like the first time I got the car, like a diesel. I would do a valve adjustment.
08.05.2020 18:23 # 20
mcanhapci99
Hi, I have the same sound in my peugeot 306 96 model 1.8 8v car knocked down the engine is running jerky, clutch and gear vibrate, so I changed the oil and oil filter a week ago, I can't find the problem
Page : / 2
