Engine cleaning recommendation?
08.05.2020 19:38 # 1
burakrak53
Guys, I say that the engine part is very dusty and I want to shine a beautiful one. Is there any cleaning material that you can use to use in engine cleaning?
08.05.2020 19:38 # 2
samet206
I am not a fan of flushing the engine. I have obtained beautiful images in this way in time.
08.05.2020 19:38 # 3
KILIC
I am washing it in a washer every 6-7 months. There has been no problem until now. Sometimes I wipe it with my car
08.05.2020 19:38 # 4
mimit
You can use the products of sonax and maguiars as amateur products. If the engine parts are to be washed with pressurized water even though they are water resistant, I recommend you to put socket inlets, sensors, exposed cables and connection points in a tape or stretch foil style product protection, cleaning of these parts. for later, you can use contact cleaning spray.
Meguiars has a dual product for engine cleaning, the first one for cleaning and the other for polishing and protection, if you say I do it myself from time to time, nice products cost about 100 lira, but the quality of meguiars is also indisputable.
If you say it is expensive, there is a cleaning product of sonax around 25 TL but after that it is useful to protect it again, since the feeders used in the normal vehicle are oily and they do not recommend using the engine, they will collect dust much more quickly.
08.05.2020 19:38 # 5
ssakyel
It was the first time I had it washed in the washer. Big smile It is gleaming. I don't know if there will be trouble in the future.
08.05.2020 19:38 # 6
burakrak53
Thanks, friends, if I find it from the latex, I will buy it in my spare time. I definitely do not recommend washing with water. I had citröen saxo before. I washed his engine with water once. I think it will be very harmful. Or you need to keep very very sensitive fragments. Already, plastic floors are cleaned with cloths and metal parts are cleaned with a material such as sonax.
08.05.2020 19:38 # 7
usta307
Brother's engine is a bit risky, especially if you didn't give gasoline engines a car model, but if the 307 fuse box is plastic, something a little bit tandem, the fuse box gets 500 tl of water, it can cause a problem. See it in one liter of diesel, fill it with 4 liters and fill it
08.05.2020 19:38 # 8
burakrak53
I heard that it was wiped out with diesel, the room made sense, I didn't hear the wd40, but I will investigate it
08.05.2020 19:38 # 9
mimit
wd 40 lubricant material gives shine but afterwards it collects dust and smells very easily, diesel oil damages plastic parts and cable protections and dries. I recommend you to wash it carefully with amateur engine cleaning products and light water. If you can even get it, you can use it for rinsing from water pressure mini hand bins. mimitan 2016-02-10 19:08:15
08.05.2020 19:38 # 10
Alicilik
I say WD40 calm. Its smell is nice, but when the engine is cleaned with it, the car smells heavy.
You can clean the engine duly. (brains are closed) If it is low pressure, it can be cleaned with warm water. They are manufactured to withstand engine and parts, i.e. under hood wet and humid environments. As long as you do not keep the vehicle in full water, there is no problem. As I said, it is useful to protect the brains and the fuse box.
I use ATAS ForEST. Depending on the dirt of the engine, I dilute 1-6, 1-7 and spray it.
I enter the bottom of the detail brush and throw the disconnected valetpro ph neutral on top. The foam is thoroughly filtered and then I clean it with a nice pressurized water. Of course, I'm doing these things at home. I have a pressure washer and a broken apparatus.
Then, as much as possible, I dry the places such as socket-connection and take the puddles. I'm planning to buy compressors for your family.
Then I run the vehicle for 15 minutes. There is no trace of water when the engine is warm.
Do not get over the top of these protective layers, it's an infamous thing.
Whenever I wash the vehicle, I also clean the hood under the hood. At the same time, I spray the ATAS PLAK2 and wipe it.
08.05.2020 19:38 # 11
Omer_mydnc
I recommend it to be a little diesel paint painters, very stranded. A nice view will come out .. :)
08.05.2020 19:38 # 12
burakrak53
I moistened and wiped the normal sponge a little
