Engine cleaning
08.05.2020 16:27 # 1
Ucyuzalti
Friends had a fat reduction in my car, I took it to the service today & nbsp; The master of the car said that the engine does not seem to have a problem, it is not like zero, it said such a blow, etc. There is no problem, the accumulated oil remains in the engine. said . Is there a simpler way to do this, that is, to make a contribution and clean the inside of the engine or otherwise?
08.05.2020 16:27 # 2
KenBlockJR
Würth has injector cleaner additives. If you take it from it and use it, you will benefit
08.05.2020 16:27 # 3
Ucyuzalti
When I say injector, do I clean the dirt inside the engine, except from the injector?
08.05.2020 16:27 # 4
06OzGuR06
They clean the resin oil in the engine that I know with hydraulic oil.
Injector cleaner does not clean the inside of the engine.
06ÖzGüR06 2011-12-16 22:43:13
08.05.2020 16:27 # 5
Ucyuzalti
20/50 If I put oil and clean it, guys will put mobile 1 & nbsp; "Big
08.05.2020 16:27 # 6
Ucyuzalti
Why did I get black without oil even 1000 km diordum & nbsp; "C & nbsp; I mean, I put the inside of the engine dirty.
08.05.2020 16:27 # 7
06OzGuR06
Actually, the engine oils we use are actually used for cleaning chemical additives, but we can understand how effective it is by trying. 0/40?
08.05.2020 16:27 # 8
Ucyuzalti
10w / 40 for sure & nbsp;
08.05.2020 16:27 # 9
06OzGuR06
Then it can be done as the master says. Clean it with new oil without adding any additives and then change the oil again. Mobile is good and I use Mobil. There is not much difference between castrol and mobil. They meet the same standards.
08.05.2020 16:27 # 10
Ucyuzalti
Well, this is really the reason for oil reduction, so if the engine is dirty, because the oil is trapped, would there be oil reduction, the oil has changed 3 thousand km. .gif "border =" 0 "alt =" C o nfused "title =" C o nfused "/>
08.05.2020 16:27 # 11
yavuz25
Look, I did this engine cleaning. It was very nice. The oil of the car was golden yellow. de & nbsp; I can tell you if you want.
08.05.2020 16:27 # 12
Ucyuzalti
It is really good and useful, my car is going like it is like engine clock but the oil reduction bothers me & nbsp; "C
08.05.2020 16:27 # 13
KenBlockJR
what you say inside the engine. it's cleaning everywhere fuel goes through
08.05.2020 16:27 # 14
06OzGuR06
[QUOTE = yavuz25] Look, I did this engine cleaning. It was very nice. The car oil was golden yellow. de & nbsp; I can tell if you want. [/ QUOTE]
Ö.m. Why are you telling us, if we write here, do not we all get informed? "Big
08.05.2020 16:27 # 15
Ucyuzalti
What I mean by the engine is not oil or fuel system in the crankcase. & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & nbsp;
08.05.2020 16:27 # 16
maestro
[QUOTE = 06ÖZGÜR06] [QUOTE = yavuz25] Look, I did this engine cleaning. It was very beautiful. The oil of the car was golden yellow. de & nbsp; I can tell. [/ QUOTE]
Ö.m. Why are you telling us, if we write it here, wouldn't we all be informed? "Big
[/ QUOTE] you got it out of my mouth "LOL"
08.05.2020 16:27 # 17
maestro
[QUOTE = Three Hundred] is not the engine, oil or fuel system. & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & nbsp; [/ QUOTE]
did the brothers explain how the old oil remained at the bottom caused it to burn fat?
08.05.2020 16:27 # 18
yavuz25
Ö.m. Why are you telling us, even if we write it here, wouldn't we all be informed? "Big
[/ QUOTE] < DIV>
I said I shouldn't write because my brother would be long but let me write it as you said. "Wink"
08.05.2020 16:27 # 19
yavuz25
Brothers, put diesel in a 1.5 liter bottle.Then go to the oiler and get 1.9 liter of 30 oil.It is possible to lift the car in the fiber and drain the oil inside the engine. .com / smileys / smiley2.gif "height =" 17 "width =" 17 "border =" 0 "alt =" Wink "title =" Wink "/> tighten the sump plug after draining the oil. Then remove the oil filter and Strain the oil and refill the same filter after the oil is left in it. Add the 30 number oil first, then add the diesel and press the starter. After the operation, the oil lamp will go out soon. Remove the filter and wait half an hour with the plug open so that it is well drained into the oil pan Then put on the new filter and replace the plug gasket to put 20/50 oil. Then drive with pleasure. We don't say we do it to someone else we don't do ourselves. smiley2.gif "height =" 17 "width =" 17 "border =" 0 "alt =" Wink "title =" Wink "/> My brothers & nbsp; I hope I could help. I would gladly answer if there is a problem.
08.05.2020 16:27 # 20
Ucyuzalti
If there is a gummy residue left, they said that the oil you added has degraded the feature, so something like that said, the oil is cleaned after changing 2 times said the inside of the engine said & nbsp;
Page : / 4
