Engine cleaning
08.05.2020 20:08 # 1
mstafasadk
I want to clean the engine as far as I have researched, it has a rust remover water top cloth and a cable cleaner that should be taken care of with the engine cleaner.
08.05.2020 20:08 # 2
Sir, if you are going to do that work yourself,
1-make sure the engine is cold
2-Fuse the electronyl electrical accents such as fuse box - ecu - well and remove the sockets you can see and spray oil-free contact into them. (You will prevent oxidation and short circuit events.)
3-There are engine cleaner products, do not use chemicals you do not know will damage metal and cables such as rust remover.
4-it is better if you clean the compressed air after washing the engine, you will remove the water and deposits left and right.
Do not get too close to the engine compartment you will clean with 5-pressure water.
I recommend using 6-motor protectors and products that prevent dust retention.
7-engine cleaner and protective products can be found on hepsiburada.com.
8- Finally, I would not recommend these procedures in the winter months, it would be better to wait for the weather to get warmer. and your cleaning will stop for a longer time.
08.05.2020 20:08 # 3
samet206
There are special products in the markets, and under the name of engine cleaner, you can clean it with a clean sponge dust-free cloth and such a product by carefully spraying it and not masking too much, and using water and minimizing the risk of oxidation and water damage. In some cases, it satisfies even if it is not a substitute for water cleaning.
08.05.2020 20:08 # 4
mstafasadk
I would like to make spray foam with engine cleaning products, not with water, but should I close any parts?
