Engine chip
08.05.2020 20:16 # 1
Cihan83
Guys, the previous day, I had oil on my car. There are small touches of oil on the oil filter. What do you think this is? 1.6 hdi partner tepee 110 before, oil pump sump and chain drive
08.05.2020 20:16 # 2
First of all, welcome, Hodja. I think it is highly probable that after the procedures you have done, I recommend that you change the oil and have a check again after 2000-3000 km. If there are still the same parts, there may be a production error in the parts where it is useful to remove and check the oil pan.
08.05.2020 20:16 # 3
Cihan83
God bless you, brother. The oil pump was not original, I changed the crankcase and got a new sump. The car has 97. The pump has changed 83. Would you like to wrap the bed or if this is the case, does the engine have a bigger head for us?
08.05.2020 20:16 # 4
[QUOTE = Cihan83] God bless my brother. The oil pump was not original, I changed the crankcase and got a new sump. The car has 97. The pump has changed 83. If you want to wrap a bed or have a motor in this stop, do you think it will be bigger or worse [/ QUOTE]
You are welcome, teacher, as I said, if there is no chip event, it is likely that it will be caused by the part that is installed.
08.05.2020 20:16 # 5
Cihan83
one
I'll make a 2 thousand km faln and look at the filter If there is a lot, I will look at the biker.
08.05.2020 20:16 # 6
[QUOTE = Cihan83] 1
I'll make a 2 thousand km faln and look at the filter If there is a lot, I will look at the biker. [/ QUOTE]
Just as the problem is caused by the replacement parts, I do not trust the industry because it is the oil pump supplier industry.
08.05.2020 20:16 # 7
Cihan83
friends this day, there was a flow meter malfunction in the service but there is no malfunction.
