Engine and transmission oil recommendation.
02.05.2021 06:46 # 1
Esdijital
Hello there. 4 days ago I bought a 2004 model 206. 1.4 x-line automatic gasoline vehicle. After the shutdown, I want to have the engine oil and transmission oil changed. When I enter the Motul site, they recommend 8100 X-CLEAN EFE 5W-30 oil for the engine, but another site recommends 10w-40 oil for the products they sell as a heavy maintenance kit. Which one should I use and how many liters should I use?
It recommends the MOTYLGEAR 75W-80 series in transmission oil, but there is no distinction between automatic and manual. And how many liters should I buy? I would be glad if you share your information on this subject. Thanks
02.05.2021 17:37 # 2
Berkay Erdinc
If your vehicle is 16v or 16v, motul recommends 5w30. If your vehicle is 8 v, it recommends 10w40.
In addition to all these, km is also important, do not skip that option in oil selection.
Again in motul oil selector It offers you transmission oils in two different ways. If your vehicle is manual, it recommends 75w80 transmission oil. If it is automatic, it is already ATF.
Choose here according to the specifications of your vehicle. Do not put the wrong oil in your vehicle just because it sells 10w40. >
06.05.2021 08:37 # 3
Ordulu adventure
If we assume that 5-30 has not been used as oil from the past to the present, it will also affect the mileage etc. When you add 5-30 oil, it may be inevitable that it will decrease over time.It is a very correct choice to use 100% synthetic motul instead of synthetic named oil of other brands. Manual, 4x4 off-road and automatic vehicles have different oil
15.05.2021 06:12 # 4
Esdijital
Thanks
16.05.2021 22:17 # 5
talip206
The recommended oil for Fully Automatic al4 gear is mobil lt71141.
I do not recommend any other brand of oil. Normally, while the gearbox takes about 7 liters of oil, it takes 3.5 - 4 liters of oil due to the torque convector not being fully emptied.
Watch out for engine oil. If the filter is not changed, it will take 3.25 liters of oil if it is changed 3 liters. Our masters, by hand, pour 4 liters of oil and then it starts to leak from right to left.
After 3 liters, check the dipstick and add it.
talip2062021-05-16 22:20:42
16.05.2021 22:45 # 6
Berkay Erdinc
It takes 3.3 liters of oil, but as you said, my master, pour 4 liters directly Big smile after the eccentric seal
Result felt will change to worn out LOL
16.05.2021 22:49 # 7
Esdijital
Yes, I bought the oil you wrote for mobil 1 for the gearbox. I will also consider your suggestion for engine oil, I will put the vehicle into heavy maintenance tomorrow. Belts, circulation pump oils, all will be changed. Thanks for your comments
