engine ** ?? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 15:27 | # 1 |
friends are coming from the places I have seen drop by drop of water but there is no decrease in water and the color of the water does not mix with red oil or something.
| 08.05.2020 15:27 | # 2 |
metin |
If there is very mild sweating there is in everyone, but if it is more than normal, the cylinder head gasket needs to change at most 400 TL.
| 08.05.2020 15:27 | # 3 |
There is no curume in the construction cover
| 08.05.2020 15:27 | # 4 |
metin |
| 08.05.2020 15:27 | # 5 |
I understand, thanks for your text. Thank you.
| 08.05.2020 15:27 | # 6 |
I had the same, a little sweating authorized service said that the 500-600 pounds would be resolved.
| 08.05.2020 15:27 | # 7 |
Thanks for sharing your information.
| 08.05.2020 15:27 | # 8 |
[QUOTE = berk2309] thanks for sharing your information, thank you [/ QUOTE] What do you mean my brother will help each other in every environment, you can bring the car to the master you take immediately, get the price from the authorized service and a few special services.
| 08.05.2020 15:27 | # 9 |
metin |
[QUOTE = azdek] [QUOTE = berk2309] thank you for sharing your information azdek [/ QUOTE] What do you mean, brother, we will help each other in every environment, you will bring the car to the master you take immediately, get the price from the authorized service and a few special services. [/ QUOTE] +1
| 08.05.2020 15:27 | # 10 |
Yes true. Don't trust the first master who came to him right away. In addition, if there is a leg there will eventually be a decrease. the liquid that leaks out of there does not exist from nothing :))
| 08.05.2020 15:27 | # 11 |
But if there is no decrease in the antifreeze, I did not wear it for 1 week.
| 08.05.2020 15:27 | # 12 |
[QUOTE = berk2309] but there is no decrease in antirestall, but I did not wear it for 1 week, very little drop by drop [/ QUOTE] If it is working, especially if it is peugeot, if it is working, it will sink into the eye that is avoiding.
| 08.05.2020 15:27 | # 13 |
take a pour radiator plug half of it. There is a possibility to deal with it and give 50 TL to bottling ...
| 08.05.2020 15:27 | # 14 |
the same leak is in me in the same place, I showed that the water is 1cm a month or a subtraction, I didn't show it.
