ENG man system faulty - Error (Pictured)
08.05.2020 20:40 # 1
MrBedO
Hello friends;
207 1.4 90 V 2009 Gasoline, No LPG installed, I have 121,000 km of vehicles.
The "ENG man system faulty" error has been lit and extinguished for the past week. I put it on the machine and share it with the following error codes and explanations.
P0136 - Taillight Sensor
- Intermittent
P1628 - Accelerator Pedal Sensor / Brake Lamp Switch. False Signal
- Security Circuit
- Continuous
P0221 - Half Throttle Position Sensor, unreasonable signal
- Intermittent
These errors I mentioned above appeared on the system. I live in the Anatolian side of Istanbul, so I will have to make these problems with a reliable service or a master at reasonable prices nearby,
First of all, I would appreciate it if you give your comments and suggestions about mistakes.
Thank you from now.
08.05.2020 20:40 # 2
dedore
I have no idea, but logically there is an error in the sensing of the flap actuating the throttle. I use pedalcommander. When you use the gas as economy mode, the butterfly doesn't open much. then the malfunction was giving error.
its source may either be the position reader next to the pedal or the valve motor may malfunction.
08.05.2020 20:40 # 3
First of all, welcome to us. One of your oxygen sensor is malfunctioning. The second one, like the accelerator, my teacher, the third fault is probably due to the faulty pedal. You need to find a good master you say, friends from Istanbul who understand peugeot will give advice on the master.
08.05.2020 20:40 # 4
MrBedO
Thank you very much for your comments.
If I go to a service on the comments you have specified, how much do the prices of such problems result in?
I understand the situations you mentioned but I will be weak to transfer them to the other side and it will not be nice for a service to know this and kiss me :(
If there is at least a number in my head in terms of order, I can agree with the service in terms of plus minus.
I look forward to your comments again.
Thanks,
08.05.2020 20:40 # 5
MrBedO
I also wrote the subject title with pictures, but I could not upload the picture. Sorry, I do not want to cause false perception.
08.05.2020 20:40 # 6
MrBedO
[QUOTE = dedore] I have no idea but logically there is an error in the sensing of the throttle actuating the throttle. I use pedalcommander. When you use the gas as economy mode, the butterfly doesn't open much. then the malfunction was giving error.
By the way, you stated that you are using Economy Mode ...
Are there such mods in this vehicle?
where should i find it?
08.05.2020 20:40 # 7
[QUOTE = MrBedO] I also wrote the subject title with pictures, but I could not upload the picture. Sorry, I don't want to cause false perception. [/ QUOTE]
hojam, no problem. for picture
The price of the oxygen sensor is around 200 TL, but my pedal is expensive, around 350-400 TL. As you said, it is hard to find good service and a master. don't forget to have the throttle cleaning done. And when was the spark plug last changed?
08.05.2020 20:40 # 8
[QUOTE = MrBedO] [QUOTE = dedore] I have no idea but logically there is an error in the sensing of the throttle actuating the throttle. I use pedalcommander. When you use the gas as economy mode, the butterfly doesn't open much. then the malfunction was giving error.
The system that our friend says is not in the vehicles, teacher.
08.05.2020 20:40 # 9
MrBedO
[QUOTE = sonerkyl] [QUOTE = MrBedO] I also wrote the subject title picture, but I could not upload the picture. Sorry, I don't want to cause false perception. [/ QUOTE]
I replaced the spark plugs as Bosh about 5 months ago. There is no problem in starting the vehicle from the ignition, spark plugs are in good condition ..
I will consider the suggestions you provided.
Thanks
08.05.2020 20:40 # 10
MrBedO
[QUOTE = sonerkyl] [QUOTE = MrBedO] [QUOTE = dedore] I have no idea but logically there is an error in the sensing of the throttle actuating throttle. I use pedalcommander. When you use the gas as economy mode, the butterfly doesn't open much. then the malfunction was giving error.
This thing called Economy Mod wrote in my car as much as I saw it ... I asked him, it could be something that can be done with a key or combination.
08.05.2020 20:40 # 11
[QUOTE = MrBedO] [QUOTE = sonerkyl] [QUOTE = MrBedO] [QUOTE = dedore] I have no idea but logically as if the throttle actuating the throttle actuated the error. I use pedalcommander. When you use the gas as economy mode, the butterfly doesn't open much. then the malfunction was giving error.
no bro, what lights on when the vehicle stopped when the vehicle stopped - tape etc. When you try to open all of them after a certain time, that text appears on the information screen.
08.05.2020 20:40 # 12
ggitaristt
It gives this error when I press the gas and brake at the same time while I am driving. Big smile
Don't ask why I pressed both at the same time Big smile
08.05.2020 20:40 # 13
dedore
:) yes, the part called pedal commander is an electronic part that adjusts between the throttle and pedal, which increases the signal speed and reaction time and amount. huh okay? some do not recommend. good in terms of use. Wired throttle (old system) feels like it. but it can shorten butterfly life :)
The economy mode article you mentioned, protects the battery when the vehicle is not running, leaving light, tape or something that consumes energy open. in this case, it gives the economy mode signal
08.05.2020 20:40 # 14
Beyinci_Ugur
First, have your engine electrical system checked because the oxygen sensor breaks down when it breaks down. The parts in the malfunctions join together in the same harness. Your malfunctions are "intermittent". Unfortunately, the biggest deficiency of the market before 2011 is the engine electrical installation problems. If you think of the anatomy of the car as parts of each human-like parts and sensors as organs, if we consider the cable connection between them as veins, we must first make sure that their veins are intact before we can decide the defect of an organ. ;)
08.05.2020 20:40 # 15
MrBedO
Last night, I showed only the fault codes to the authorized service after the work, shared that there will be repairs or product changes related to these problems, and an average of approximately 400 to 1600 TL will be eliminated. They also stated that they could make different determinations because the program looked different.
Obviously, the fee policy of the authorized service scares me. I would be very happy if anyone knows and recommends the private service on the Anatolian side of Istanbul.
Thanks,
08.05.2020 20:40 # 16
dedore
[QUOTE = MrBedO] Last night after work I showed only the fault codes to the Authorized Service, shared that there will be repairs or product changes related to these problems, and an average of about 400 to 1600 TL will be eliminated. They also stated that they could make different determinations because the program looked different.
Thanks,
Most of the authorized services are money traps. I witnessed replacing even the solid part by saying it was broken. it makes more sense to go to a private peugeot gear. As a result, the ongoing warranty on the vehicle has expired.
They can even find the piece by trying to guarantee the diagnosis.
30.03.2024 11:46 # 17
YKH
Hello master, is the problem you experienced solved? I am having the same problem in my vehicle. The throttle body was cleaned and the problem did not go away. The butterfly was changed and we got the same error again. If the problem is solved, I would be very happy if you could inform me.
28.10.2025 00:33 # 18
Oguzhan207
I had the same problem today while waiting at the traffic lights. The car suddenly stalled and wouldn't start for 10-15 minutes. Then it started and gave an antipollution fault and an eng man system fault warning, along with the engine fault light and the exclamation mark ⚠ warning light. Did you find a solution?
