"ENG MAN SYSTEM FAULTY" error
08.05.2020 14:53 # 1
t@lip
I congratulate everyone's Ramadan feast. I would like to get your ideas about a problem I have recently experienced with my wishes to reach the next nice holidays as Pug family. My Pug 207 1.4 HDI Trendy car, though not always, when it is difficult to press the gas at some times, it automatically cuts the gas itself and lights the service lamp with an exclamation mark in the triangle, and displays the message " ENG MAN SYSTEM FAULTY " on the screen accompanied by beeping beeps and starts to slow down. (already cut off the gas itself) everything is returning to normal. I went to a Bosch Service on the road because it had Pug Planet software. 4 different malfunction records, which are not related to the faulty motor, such as throttle pedal position malfunction, brake sensor malfunction. Doesn't matter on the spot, a little bit of difficulty Since there was a PO station near my house, I was buying the fuel from there, and when the error first appeared, I immediately bought a diesel fuel of 120 TL from OPET on suspicion that it was due to diesel. The problem still persisted. If you have experienced this problem, I would be glad if you share it. I did some research on the internet, but I couldn't find much. I just understood that the message opening was encountering an error in the Engine management system faulty, ie the engine management system. If it doesn't improve after the holiday, I will take it to the service, I wanted to get your opinions before that. Happy holidays again, stay healthy!
08.05.2020 14:53 # 2
MaximuS
I hope it is a minor thing and you will not have a lot of expenses ... Happy holidays, by the way ...
08.05.2020 14:53 # 3
Have a nice holiday,
After some research, the information I have gained is:
The computer unit, which we call the brain of the vehicle, works as long as it receives data from different sensors from different units in a healthy way. As in your case, one or more units may be broken. However, I do not think it is due to diesel oil. The reason for the vehicle to start slowing down is that the vehicle is going to the safe mode after this error. If you could get the codes of these errors, maybe we could do some more searching.
08.05.2020 14:53 # 4
t@lip
Thank you for your comments, friends, the way of the service appeared :(
