Eng man system faulty
08.05.2020 20:48 # 1
endorphine
Hello. When I run the tool, I get the error in the header. An exclamation mark appears on the instrument panel as well. There is no problem with the vehicle's driving or engine noise. I would be happy if anyone who has knowledge or knowledge helps.
08.05.2020 20:48 # 2
endorphine
I think there is no answer. Tomorrow, I will take it to the master of my previous vehicle (opel). Connect to the computer and see what happens. How many years has already been muddled my stomach. We use the vehicle on weekends. We are not going on such a long road. I also take care of it on time. It's not about using hard. At the age of 12, 58 thousand more kilometers. Think about it now. So if we use it too much, the vehicle will have no place to hold. Let's take care of this malfunction, this year I have put the change in mind. I am thinking of buying a German or Japanese brand.
08.05.2020 20:48 # 3
atasoy
It is because of the LPG ... There will be some information on the internet ... A friend wrote: I went to the service yesterday, for this breakdown ... I said that I will look at the bugs in the Bayrampaşa pug service, I will not do maintenance first, just on the computer. eng man said that the system faulty and antipollition faulty errors are related to the fuel system, because the vehicle is scuba, the butterfly through which the fuel passes is made for liquid passage and because the gas is not a rich mixture, it perceives it as an air intake and the brain gives these errors. And he said this without looking at the vehicle, they didn't put my car in the ground floor services because it was already scuba. He also said that I would often encounter this error. It has been 9,000 km since I bought the car and started to give this error this week ... I came back from the door. Unfortunately he gave the error again this morning :(
08.05.2020 20:48 # 4
endorphine
No LPG in the vehicle. I have researched too. But it was a general fault notification and it had to be connected to the computer.
08.05.2020 20:48 # 5
HasGur
An ECU (engine management module) malfunction ... If the ECU is not faulty, it usually occurs when communication with an electromechanical part that is controlled by this module is interrupted. When connected to the computer, it becomes clear which part it originates from.
The 2006 model vehicle is 13 years old, did you take your 58 thousand vehicle zero? If you are the first owner, if no LPG has been installed and you are thinking of selling seriously, we can talk.
08.05.2020 20:48 # 6
endorphine
I bought it in 37 thousand. The housewife was the previous owner. He brought the children to school. No LPG was installed. The km is low as it is mostly used close to the weekends.
