Eng Man. System Fault
08.05.2020 17:38 # 1
turshu
Hello friends, I get "Eng. Man. System Fault error" in my 307 1.4 90bg Gasoline LPG vehicle. When I start, the cycle travels between 800rpm and 1500rpm and the accelerator pedal locks. When I restart the car, the error continues, the accelerator pedal returns to normal, but the car falls out of traction. This is happening in gas.
Have you been encountering this situation? What's the solution? Thank you for your help.
08.05.2020 17:38 # 2
tellotello
Hello there,
There is something written by a citroen user who has encountered a similar problem here, maybe it will help you. It will share with friends who have knowledge about the subject. Get well soon.
08.05.2020 17:38 # 3
turshu
Thanks. I think I found the problem. Due to the lack of contact between the cables from the ECU to the throttle, the cables do not come in contact with the engine vibration when the starter is pressed. The Buddha is shedding the butterfly. I will test for a while, I will give information about the result.
08.05.2020 17:38 # 4
emre_akdag
I think you should have a pc connected in the service. Get well soon.
