Emergency wrapping of 307 beds
08.05.2020 15:51 # 1
Eskobar
Hello friends.
Friends, we bought a vehicle 100 km. There was a problem with the engine on the road and I do not have the slightest problem. While the vehicle was running, there was a small noise coming from the engine, a thin voice, then it turned into a blast afterwards, but when the vehicle was idle, it made more noise and the pressure decreased when the gas pressed. mahmutbey gave a battery error at the toll booths, I think the electric warning lamp was coming from the smell slightly, then we pulled the right, we rested the engine, we turned it on, we saw the tharzers, they showed the dynamos and the coil underneath, they said to go to the mechanic, go to the mechanic 90 (middle of the indicator) and It went down to a very low level of 70 when it came out, so we did not worry too much about the car, but when we came home, the sound got a little more and the smoke was thrown, we left it there. Now, because the car is entrusted, whatever the owner says is ok, the master looked and wrapped a bed from the top, so we do not trust the owner very much, so I wanted to share it with you. Also, can you explain if the heat is not full in the mattress wrapping? If the bed was wrapped, what would we save on average? I have researched a little, they say that the dynamos of the chargers say they come from their coals in smell, but it is a little thought to call the bed wrapping because there was no problem in the heat.
08.05.2020 15:51 # 2
metin
eskobar öncelikle geçmiş olsun. Size yardımcı olabilmemiz için sizi tanımamız gerekiyor. bu yüzden forum kurallarında da belirttiği gibi yeni konu açmadan önce kendinizi tanıtmanız gerekiyor. profil bilgilerinizde il ve ilçe bilgilerinizi yazarsanız yakında olan usta tavsiyesinde bulunabiliriz. ayrıca aracın modeli yakıt türü motor hacmi vs nedir bunlarıda imza bölümünüzde paylaşmalısınz. metin2011-07-18 17:08:24
08.05.2020 15:51 # 3
berk2309
if you call emergency, let's try to help if the electric battery charge signal came out, look at the motor pulley first thing happened in me. When the pulley is discharged, it lights up when it doesn't charge
08.05.2020 15:51 # 4
berk2309
As I was going to Mersin, the engine started to hear the sound of the engine, I looked at the hood, I looked at it, the pulley was empty, the two cast iron sounded like a knocking sound.
08.05.2020 15:51 # 5
Eskobar
I made the introduction of Metin Bey, but I do not know exactly the model of the vehicle, but it is not the hd, but as I wrote, it was a safety car. light smell of plastic burns
08.05.2020 15:51 # 6
metin
I don't know where the gop is.
There are sponsors at the top of the page, there is peugeot efe, it provides both parts and service.
AUTO EFE
Peugeot & Citroen
Dismantled Spare Parts
0212 486 33 66
I www.peugeotcikmacisi.co
I www.cikma-parcaci.co
Tell me it's from this forum, it helps.
08.05.2020 15:51 # 7
106_arts
friends, they say so, you will get it, you will take the car and show it to your master, what is it, you will act accordingly
08.05.2020 15:51 # 8
Get well soon
08.05.2020 15:51 # 9
Eskobar
friends, if the subject I get stuck in the vehicle's engine, it causes heat.
08.05.2020 15:51 # 10
metin
[QUOTE = Eskobar] friends, if my subject is sound from the vehicle's engine, the temperature will not rise because it causes heat. My point here is [/ QUOTE]
Have you met peugeot efe?
08.05.2020 15:51 # 11
Eskobar
I met now, I bought a mobile tlf, he said, let's look after work, he said he was on his way, but he said at the cost in the car. Even though he may be trying to break us off, I do not want to take his sin in him, but he says that everybody I see is not wrapping the bed, so I got stressed, my head is very confused in the evening, I will turn back to you.
08.05.2020 15:51 # 12
metin
[QUOTE = Eskobar] I met you now, I bought mobile tlf in the evening, let's see the work out, he said he was on his way but he said at the cost in the car, the owner of the car took us the cost of 2700 TL, we wanted 1000 TL from us. No matter how close we are to the owner of the car, he may be trying to break us off. Of course I do not want to take his sin in him, but he says that everyone I see is not wrapping the bed.
Efe helps you. You say that the vehicle is walking, I think the bed will not shake. I think it might be a job.
08.05.2020 15:51 # 13
A difficult situation, get well soon ..
08.05.2020 15:51 # 14
Eskobar
Efe said thank you, come and look, but what happened is that the car has already started to be repaired. If we come to the game now, let's say earring in our ear, I had a car for 5 years, I did not have this kind of problem.
