Emergency vehicle is receiving water
08.05.2020 19:29 # 1
Eguzhan
Emergency help friends 2001 model 106 quicksilver I have the car when the car is parked on a flat surface under the rain in the right passenger part that I bought the mop in it ten ten silegec looked the drain pipes, no dirt, poured glass, went to the car did not take it in the vehicle There is no wetness next to the torpedo, no mat on the dry floor, no wet wipes, no glass wicks in the door, I looked under the door expense, open them. I don't understand if he takes it from there or a little above.
08.05.2020 19:29 # 2
hakanerbas
Is there a sanroof in the vehicle, brother
08.05.2020 19:29 # 3
Eguzhan
No money, brother, I couldn't find one, some friends say change mosque shock fits, but what
08.05.2020 19:29 # 4
hakanerbas
There is a possibility of getting it out of the windshield, but generally it is caused by the obstruction of the windshield ducting channels down there. If you want someone can pour water on it and look at it from the inside, so you can understand it better.
08.05.2020 19:29 # 5
Eguzhan
I poured water from the drainage channel that I tried, it does not run through the drain channel, it does not come in. The only possibility is digidtircen
08.05.2020 19:29 # 6
Eguzhan
God again, again, this is the following.
