Emergency support is on the way
08.05.2020 20:30 # 1
osmgltk
Hello friends.
I took a break with my car on the intercity road and when I run it again, the marsa press sounds like a tick click, and then there is water on the screen and it doesn't work. Is it a problem I can solve by myself? I don't know where the diesel filter is. I cannot reach because the services are closed market. I'm stuck.
I would appreciate it if there are friends who can help immediately.
08.05.2020 20:30 # 2
Baris307
You need to change the filter, but if you find it hard to be a market, try to drain it as much as you can to drain the water inside but this is a low chance.
08.05.2020 20:30 # 3
osmgltk
Where can I insert the filter manually. Peugeot tepee 2011 1.6 engine
08.05.2020 20:30 # 4
maximusti
I hope I found a video like this.
[TUBE] rjzvq8qc7nk [/ TUBE]
08.05.2020 20:30 # 5
osmgltk
Thank you to the interested friends.
Let me write down the problem, maybe someone else needs it here.
The diesel filter was water warning on the radio screen. So we looked for the solution there. But the trouble was caused by the dead battery. After charging the battery, we continued on the road, but it cost me 3 hours. Good forums
