EMERGENCY STEERING HYDRAULIC AID
08.05.2020 16:18 # 1
friends last year, 106 xs I bought this month was the steering wheel stiffness problem. ..
Can I save the cost at minimum ...
08.05.2020 16:18 # 2
Check the steering fluid is missing, complete it, do it a few times, right, right, left, while doing this, get the car running, then complete it again, complete it and experience the car when it reaches the normal level. id = "isChromeWebToolbarDiv" style = "display: n o ne">
meanwhile, don't use the brake fluid instead of the brake fluid.
Reviews
08.05.2020 16:18 # 3
34sea45
Don't you think the hydraulic pump has fallen over like me?
Since the bar does not press enough, the steering is like a 52 model man truck :)
08.05.2020 16:18 # 4
I Love My Pug
Ilhan abicim ATF passes my Automatic Transmisson Fluid, what you call ATF? I got hydraulic oil on it, I have a gear photo on it, I asked someone said this is the oil of the automatic gearbox ?? I Love My Pug 2011-10-28 17:21: 50
08.05.2020 16:18 # 5
I Love My Pug
I Love My Pug 2011-10-28 17:21:32
08.05.2020 16:18 # 6
do you think that the pump may have been damaged, it was used without hydraulics for 1 year. 22 "width =" 31 "border =" 0 "alt =" Don't cry "title =" Don't cry "/>
nothing has happened or I get rid of it with little expense for help Thank you guys ..
street art 2011-10-28 17:51:57
08.05.2020 16:18 # 7
Atf oils are used in many different areas, for example, the gearbox and hydraulic system used in our municipality are used to split it, but although the oil we call atf 2 is the same color and darkness, we use it as a dissection fluid. Be careful to write "hydraulic steering oil" under it. Whatever happens, it is easy to come
08.05.2020 16:18 # 8
I Love My Pug
Thank you thank you .. :)
08.05.2020 16:18 # 9
I have been asking the hydraulic pump since the bad morning, the prices are not very salty. = "smileys / smiley11.gif" height = "15" width = "25" border = "0" alt = "Wall" title = "Wall" />
08.05.2020 16:18 # 10
34sea45
hydraulic pumps come off from 250
If the pump is running but not catching enough bar it will be repaired but if it stopped completely, the worst 250 goes to 300
08.05.2020 16:18 # 11
I Love My Pug
I know the steering box is between 1,000-1,500 pounds, I asked for my own car, is it so expensive in the 106s?
08.05.2020 16:18 # 12
ahmetismet
My car 307 2004 model, when I bought the steering pump was missing oil. The master said, use it as soon as possible, add it sometime, he said. I have made two of them in 1400, the steering pump has completely changed, the steering box seals have been renewed. Now there is no problem.
08.05.2020 16:18 # 13
I Love My Pug
A lot of money, I'll increase your circulation to 2 thousand TL, what is the steering box and so much money?
08.05.2020 16:18 # 14
The same problem happened to me 5 years ago, I had vts, the pump was broken, zero price, then 850 TL. I had found and installed the 150 TL, the pumps of 106 and saxo are the same.
08.05.2020 16:18 # 15
900 tl hydraulic pump 900 tl steering box was said to me, except for workmanship, thank you guys for your help and comments. strong> many thanks again ... "Applause" < / em>
08.05.2020 16:18 # 16
by_imp
If you tell us how you got it, my teacher, we will be informed
08.05.2020 16:18 # 17
[QUOTE = by_imp] you will be informed about how you dealt with my teacher [/ QUOTE]
& nbsp;
Yes, I agree ... You haven't written so much subject but you haven't written your solution ... "Blink"
08.05.2020 16:18 # 18
walla brothers, as I wrote before, my brother went to the repairman 29 october I told him after the incident, he removed something from under the engine, he did a little bit of his own & nbsp; the rest was sent to the electrician, and now he is much better when he says hydraulic oil & nbsp; ..
thank god I got rid of the salty expense ...
