Emergency Steering Does Not Turn!
08.05.2020 18:00 # 1
xMEGANx
I just turned the steering wheel of my friends Princess to the left (I was turning) suddenly hardened now it does not turn hydraulic cancellation I turn it like a trucker, did I barely take out the fuse?
xMeganx 2013-10-17 17:35:55
08.05.2020 18:00 # 2
kuscu38
the hydraulics of the draction and the belt of the air conditioner The V-belt either has a problem on it or on the V-belt bearing, open a hood on the ball or something.
08.05.2020 18:00 # 3
xMEGANx
[QUOTE = kuscu38] the hydraulics of the draction and the belt of the air conditioner The V-belt is either a problem on it or on the V-belt bearing, open a hood on the ball or something. The ball should be somewhere on the right side of the engine. QUOTE]
brother, the new chassis in the 307s steering I took it to the electronic service, they looked at them, they said electronic, they said we can not see, they referred to the electrician
08.05.2020 18:00 # 4
Sertan
teacher, follow me if you find the solution.
08.05.2020 18:00 # 5
xMEGANx
[QUOTE = Sertan] I will follow my teacher. Could you share the solution. [/ QUOTE]
Got the same problem, hodja?
08.05.2020 18:00 # 6
error
There may be a problem with the electronic pump in the hydraulics or the fuse if any
08.05.2020 18:00 # 7
xMEGANx
[QUOTE = errör] bypassing the electronic pump, there may be a problem with the hydraulics or if there is a fuse [/ QUOTE]
Here is the MAXI fuse box where this vehicle could not find it. There is no 70 fuse in the front of the engine and steering wheel. According to the booklet, there are MAXI insurances, but they do not say where they are.
08.05.2020 18:00 # 8
error
huh, you say it dude, the battery is right there under the hood prd: D
08.05.2020 18:00 # 9
rolandgarros
If I think the power steering pressure pump cort cort, get well soon.
08.05.2020 18:00 # 10
xMEGANx
[QUOTE = errör] huh, you say it, brother, I woke up under the hood of the battery now prd: D
I think MAXI FUSES BOX is the peace that we are looking for, the paradise we are looking for :) dee in which part of the puzzle under the hood we will find it.
xMeganx 2013-10-18 00:38:15
08.05.2020 18:00 # 11
xMEGANx
[QUOTE = rolandgarros] If I think the power steering pressure pump cort cort, get well soon.
So how much are these Cortlak Purrs to us? for example? including average workmanship? or repair?
08.05.2020 18:00 # 12
error
08.05.2020 18:00 # 13
xMEGANx
I looked over there, where there is no wonder if there is the highest 40 fuses there
08.05.2020 18:00 # 14
ozknckr
First of all, get well .. I had the same incident with me, I think you will always be with you and have it repaired :))
Two months ago, remove the terminals .. remove the cover of the fuse box in the photo shared by errör .. There are cables coming from the terminals of the pole. Take out the box .. You will see `` maxi fuses '' under the fuse box.
3. It should be green .. It should be ... It is mine too ... But be aware that this could be a temporary solution .. I had to repair it .. No problem right now ...
Again get well soon...
08.05.2020 18:00 # 15
xMEGANx
I made friends 200 liters of the steering wheel to the end of each cycle, instead of throwing fuse, the cables were burned, now they separate the cables, they put something in it.
do not turn the steering wheel to the end
08.05.2020 18:00 # 16
alpercakan
It is not a matter of spinning, it does this when it hurts at the bottom.
