Emergency Starter does not press!
08.05.2020 17:44 # 1
phoenix.1905
My car with the friend does not click on the marasha pressure. Only the battery sign is flashing. But there is no problem with the battery. This happened to me a few times, and when I turned the ignition by pressing the impact sensor, the vehicle was running. Today I parked the uphill vehicle. Since the time has come to change the pressure pad, I said experience that the vehicle is missing in gear. I tried and missed it in gear. Then I said I'll take it forward, but the starter doesn't start. I tried pressing the impact sensor again, it doesn't work. I'm now in another place and need to start the car, waiting for your help?
08.05.2020 17:44 # 2
emre_akdag
starter dynamo .. there may be a shortage of coal ..
08.05.2020 17:44 # 3
rolandgarros
if not battery, it is made of starter coal
08.05.2020 17:44 # 4
ErolSs
friends are telling the right mars engine coals are exhausted
08.05.2020 17:44 # 5
phoenix.1905
Thank you for your answers .. I would have shot it if it were straight .. Then I'll have to do a little more to run it.
08.05.2020 17:44 # 6
phoenix.1905
Friends tried it in a single try I tried again after 2-3 hours. In this event, can we say from the exact starter coals? What is the price for 306?
08.05.2020 17:44 # 7
Serkan
My teacher does not make a starter, even if it is made of coal. The starter automatic (also called starter) may be stuck. When it is not working, try to click on the starter motor with a small hammer.
08.05.2020 17:44 # 8
phoenix.1905
May be .. thank you ..
08.05.2020 17:44 # 9
howard
A CLICK SOUND WHEN THE CONTACT RUNS, BUT IT DOESN'T WORK BETWEEN THAT IT IS 100% COAL AND IT IS RELEASED BY PLASTIC THAT IS IN THIS COAL. 45TL COAL KEEPED 20TL PLASTIC 30TL WORKED AT 30TL GOOD BIT A MASTER THERE IS A TEFERRUAT. HOW DID I REMOVE FROM THE SUBWAY, I WON'T REMEMBER THE NAME OF THIS TIME TO REACH. WATER HOSE WAS REMOVED ON A WELL-WINNING ROAD WITH ITS OWN FACILITIES. SERKAN MAY BE SURE WHEN THE BRAIN SAYS BUT HOWEVER I AM SURE THAT I HAVE BEEN SURROUNDING THAT, THE BİDA HAS NEVER REPUTED THIS PROBLEM. I HAVE USED IT TO ME AND LASTED HAPPENING AT THE LAST NO WORK. howard 2013-06-25 17:22:38
08.05.2020 17:44 # 10
phoenix.1905
I will take you to my master in the coming days .. let's see what will come out .. Click for your comment ..
08.05.2020 17:44 # 11
faldov
Last week, I said I would do the maintenance before going on a long road.I had been in my mind for a long time. TL cost 85 in total.
08.05.2020 17:44 # 12
elestern
my teacher stared at the automatic starter, it happened to me, as if they stole the starter motor, there is no sound, but once in a while it is not clear where to leave the starter automatic.
08.05.2020 17:44 # 13
emre koksal
Hi
In my 206 hdi diesel vehicle, the mars click sound was not making and the vehicle was not running.
The commands of mars dynamo and the upper part of the dynamo were changed.
the commanders were less than half.
It took about 2-3 hours.
It cost 165 rubles, including heating and parts.
In the problems related to electricity and rubber, you can go to the bulletin of Ankara with the comfort of Ahmet usta yaç.
There is a th battery sign at the exit from the bulbulder, after passing the lights of the pilgrim over the left side ...
Good luck with...
