Emergency selection of 306 xr sequential system
08.05.2020 15:57 # 1
67as306
Friends 1998 sedan 1,8 306 xr war milano old queue system is plugged in but I am waiting for your suggestions to install a new inline system.
the albaydemirc 2011-08-06 00:41:19
08.05.2020 15:57 # 2
turan306xr
write to cecoli, it helps you
the cecol 2011-08-08 15:47:58
08.05.2020 15:57 # 3
Turan brother greetings ... Göz Kırpma We do not use big letters
I replied to this issue before, I wonder what happened ...
08.05.2020 15:57 # 4
As it is known, the master who assembles the lpg system should be good ... after a proper assembly, you can have every brand of lpg installed according to your budget ...
08.05.2020 15:57 # 5
[QUOTE = OsmaNDogaN] does not matter the brand, as it is known, the master who assembles the lpg system should be good ... After a proper assembly, you can have every brand lpg installed according to your budget ... [/ QUOTE]
Only Osman's brother's friend's engine is the same as mine. This engine doesn't have full-rank spraying, like leaks. It works with half-row spraying. Because of that pain, every system may not work properly with us. Another friend had a brc installed on this engine. I don't know what happened in the last situation.
I am sure that the waste that I use in myself is working properly. Sırıtma
08.05.2020 15:57 # 6
[QUOTE = CeCoLi] [QUOTE = OsmaNDogaN] brand does not matter, as it is known, the master who assembles the lpg system should be good ... After a proper assembly, you can have every brand lpg installed according to your budget ... [/ QUOTE]
it is true you are right cem my mind went to full rank system sorry Sırıtma
