emergency relief for freezing wiper water
08.05.2020 21:06 # 1
ilter81
Hello friends 308 wiper water froze 2 weeks ago. I forgot to put antifreeze glass water. Even though I do not put 2 liters of antifreeze water on it, it did not dissolve even in 8-9 degrees weather. What should I do? or is the engine likely to freeze. hoses might be frozen. What should I do, I would be glad if you could help
08.05.2020 21:06 # 2
Karacocuk24
Look at the ends of the water sprinkler, open the hood, look at the hoses below, if there is no frozen sound in them, you need to find the insurance and look at it, someone who knows better
08.05.2020 21:06 # 3
ilter81
okay I'll be up tomorrow. thank you so much
08.05.2020 21:06 # 4
GokhaN
The best control is to open the hood, remove the sprinkler hose under the felt, and then go on to the other stages if water is going to the head arm.
08.05.2020 21:06 # 5
ismailkaya
First of all, if the glass water engine is running, look at it, if it is running, you can apply what I wrote. turn the right front wheel to the left, remove the hood by the front fender, look out from the front, you will see the glass water engine, pull it out, there is a plastic gasket when you take it out. Whether it is the right plug when installing meat, let us take the pine juice motor, blow hoses as it is clear that the hoses are open. The place that is obstructed is probably not functioning when the clay is mud inside the mechanism with two connection outputs of the hoses. If you live in a district of 5,000 inhabitants away from the city like me, you have to do everything yourself.
08.05.2020 21:06 # 6
ilter81
Brother I gave you the prescription but I don't know if I do it. I probably can't collect it. Thank you, I will try again very hard
08.05.2020 21:06 # 7
ilter81
Thanks to your friends for your help again. The problem was solved when it changed
08.05.2020 21:06 # 8
I'm glad your problem is solved, hodja.
08.05.2020 21:06 # 9
ilter81
thank you
